Old 12-18-2017, 08:08 AM   #1
D13
D13's Avatar
It's Christmas - what did you get your square?
What did you get your square this year?
Mine got a 208C for parts, a 700R4 case for mock up, a front drive shaft, a new valve in one tire, and a set of door seals waiting to be installed. What makes this funny is none of my current trucks are 4wd.
Also bought it Mtripacks and crimpers for that big rewire job on the 77. Ass soon as the 87 gets refreshed and the 81 scrapped and...
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
Plus a mess o' tractors
D13 is offline   Reply With Quote
Old 12-18-2017, 11:27 AM   #2
Rich84
Rich84's Avatar
Re: It's Christmas - what did you get your square?
I'm gonna ask Santa for Vintage Air..
Rich84 is offline   Reply With Quote
Old 12-18-2017, 11:55 AM   #3
rustyfive-seven
fresh heads and all gaskets to reseal my 77s 350 and a mcgaughy 5/7 drop
rustyfive-seven is offline   Reply With Quote
Old 12-18-2017, 12:21 PM   #4
RedBed
RedBed's Avatar
Santa is definitely dropping off a few boxes for my '79. Coverlay dash cover, dash lens, clock, temp gauge, rubber flooring + I already have a real nice seat cover and Stereo waiting to be installed. Yea Santa! Or is that Visa-Clause?
1979 Chevrolet Bonanza/305/4L60/Edelbrock Performer/Holley 600 Classic
RedBed is offline   Reply With Quote
Old 12-18-2017, 12:41 PM   #5
bluex
bluex's Avatar
Sniper EFI, Dual sync distributor and the requsite timing/fuel system components.
bluex is offline   Reply With Quote
Old 12-18-2017, 01:00 PM   #6
RotaryRocketeer
RotaryRocketeer's Avatar
New vents, climate control vacuum harness w/adapter, and a 200-4R to build so she can finally experience OD!
RotaryRocketeer is offline   Reply With Quote
Old 12-18-2017, 01:03 PM   #7
riz
Rear axle seal and bearings, front spindle seals and bearings, inner and outer tie rod ends, idler arm, pitman arm, adjuster sleeves, pre bent stainless brake lines with all the clips...more to come like Moser differential cover, rear mount gas tank, lowered front and rear shocks, etc.........
RIZ
81 C10 short box
82 K5 Blazer
riz is offline   Reply With Quote
Old 12-18-2017, 01:14 PM   #8
Gregski
Gregski's Avatar
a brand new cheap plastic radiator, not by choice, lol
Gregski is offline   Reply With Quote
Old 12-18-2017, 05:12 PM   #9
TKCR
TKCR's Avatar
New Paint!!
Old 12-18-2017, 08:09 PM   #10
Nuckingfuts
We're dropping the engine/trans this weekend on my son's '73 to swap out some gaskets, freshen up the block paint and engine bay paint but most importantly are the goodies that santa has in store that he doesn't know about.
Freshly powder coated rallies (with Cooper Cobras on the way)
Summit Vortec heads (along with manifold and 10" torque converter to match hp bump)
Nuckingfuts is offline   Reply With Quote
Old 12-18-2017, 09:05 PM   #11
S10Fan
Old Heap Driver
Mine is currently on jack stands awaiting removal of the front clip and 454/700R combo. Pulling the drive train for updated paint, while the motor is out the under hood area is getting cleaned up and painted. Refreshing the air ride with new bags, lines, fittings, a VU4, and new compressors. New exhaust including Chevelle/Camaro headers and everything from front to back.
My super nice square ended up getting neglected for the last few years, it's time for her to shine again.
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline   Reply With Quote
Old 12-18-2017, 10:26 PM   #12
natedogg
Santa is bringing me a fresh 350 thats at the machine shop now.
natedogg is offline   Reply With Quote
Old 12-18-2017, 10:28 PM   #13
truckin 79
Wow my truck is not so lucky as others. My truck is getting used stuff like last year. I just got back from the junk yard this weekend and got some good stuff, chrome valve covers 12.00, lt blue map pockets just needs new elastic 4.00, plastic gauge bezel 12.00 and a lt blue arm rest free.
79 Chevy 2wd BIG10 350 TH400
truckin 79 is offline   Reply With Quote
Old 12-18-2017, 11:57 PM   #14
Warrens69GMC
Warrens69GMC's Avatar
Door panels from LMC for my 1978 Big 10
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 12-19-2017, 02:29 AM   #15
nonstop
My truck got some new front brake calipers and a parking brake band! Theme going!
nonstop is offline   Reply With Quote
Old 12-19-2017, 10:09 AM   #16
SunSoaked
SunSoaked's Avatar
Summit aka "santa" will be delivering my package this evening: GM Vortec heads, manifold, Comp 256 cam and roller rockers. The cherry on top will be a Holley Sniper dressed in gold.
SunSoaked is offline   Reply With Quote
Old 12-19-2017, 10:14 AM   #17
SunSoaked
SunSoaked's Avatar
Attachment 1718195
Attachment 1718196
I got Summit Vortec heads (gm) coming tonight too. Your pic of the heads appear that they have screw in studs for the rockers? Did you upgrade to screw in or are those Summit brand vs gm?
Old 12-19-2017, 10:46 AM   #18
Nuckingfuts
Summit vortec heads (aka Dart heads) come with screw in studs.
https://www.summitracing.com/parts/sum-151124
Old 12-19-2017, 11:23 AM   #19
RedBed
RedBed's Avatar
Junk yard treasures are better than store-bought! Nice!
Old 12-19-2017, 12:04 PM   #20
Man With A Gun
Man With A Gun's Avatar
My 77's getting a powder coated glide out tire carrier from 1774btccrew!
77 Chevy K20 Longbed
86 GMC C3500 Dually
07 Silverado 2500HD
All standard cabs
Man With A Gun is offline   Reply With Quote
Old 12-19-2017, 01:35 PM   #21
Nuckingfuts
Pics?
Old 12-19-2017, 02:52 PM   #22
D13
D13's Avatar
that's why I have 5 - if it ain't made of rubber I pretty much try to rob it if possible. CL is my friend! Now if only someone had an 87 GMC 3/4 4wd that needed a body and a motor... and was near me... and cheap... Sigh.
1987 2 ton
Old 12-19-2017, 04:39 PM   #23
jrpontiac
jrpontiac's Avatar
3" Dropped spindles
jrpontiac is offline   Reply With Quote
Old 12-19-2017, 05:06 PM   #24
Matt Man
Matt Man's Avatar
Santa is bringing me a deep transmission pan for my 81 and a sway bar disconnect kit.
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11
1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020
67 GMC Stepside Straight six/3 on the tree "The Peach"
2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver
K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934
The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903
Matt Man is offline   Reply With Quote
Old 12-19-2017, 05:21 PM   #25
bluex
bluex's Avatar
My Sniper arrived today. Its so pretty
