12-18-2017, 12:04 PM | #1 |
Manifold coatings
Guys
Putting a 261 in my 49 3800. Keeping the truck a rat rod except for cleaning up the motor and repainted it. Now to the manifolds. I have them apart to put in a new gasket and wondering what other guys had done. Motor looks good so I thought of having the manifolds ceramic coated. What have guys done meaning fully re-assemble and then have them coated or leave apart and have them coated? |
12-18-2017, 12:45 PM | #2 |
Moderator
Re: Manifold coatings
Jet hot has some very good looking cast iron gray coating. I plan to use that myself.
12-18-2017, 04:23 PM | #3 |
It's Better With Nitro
There are a lot of different colors in ceramic coatings now. Most recently, I had my local powder coater coat some of the parts on my Pontiac 194 Trophy 4 cylinder, including my intake and M/T valve cover the factory early Pontiac blue, and then the RAIII exhaust manifold a cast grey ceramic.
12-18-2017, 08:30 PM | #4 |
^^^ that's sweet. I've seen a lot of different engines over the years, but I've never seen one of those before.
12-18-2017, 09:59 PM | #5 |
I like ceramic coated.
12-19-2017, 12:06 AM | #6 |
60-66 Nut
Proper prep is very important is a exhaust manifold coating's durability. Sandblasting is the best IMO. In the past I have used wood stove paint with excellent results. Stove Bright brand is the best. It can be found at Lowe's or most stores that sell wood and/or pellet stoves. It comes in many colors as well.
