12-18-2017, 01:25 PM | #1 |
Who make the best wheel adapters?
As the title says, who makes the absolute best wheel adapters? I don't really wanna use them but have no choice. Looking for 5x5, 2", preferably hub-centric. Adaptitusa.com has USA made ones, even with 14x1.5 lugs to match my front rotors, but I believe theirs are lug centric.
Thanks |
12-18-2017, 02:03 PM | #2 |
Re: Who make the best wheel adapters?
Never use adapters , Buy the right wheels or the right parts to fix the problem .
12-18-2017, 02:40 PM | #3 | |
Well, my rear end is 4" narrower than my front assembly. I can run it as is but it looks funky from the back. I would need a 2" backspace rim, or a 4" wider differential, or wheel adapters. I don't think the first two exist. |
12-18-2017, 04:08 PM | #4 |
I'm curious as to what you're wanting to run these on and what wheels specs you currently have? I have 6" BS fronts and 4" BS rears all on 22x9s and that looks pretty good on my '68. My point is, you don't need impossible to find wheels to eat up the difference in front to rear track width.
Builds: Green Gus the 68 C10 | Bluey the 72 1500 | Lowly the 70 C10 - Instagram: @dr.hewitt - C10 Concept/Development Photos: Master Thread |
12-27-2017, 11:21 AM | #5 | |
Front is perfect, back is really close to the frame and can rub, need them kicked out a bit. |
12-27-2017, 12:54 PM | #6 |
Try wheeladapter.com. Fred goeske. He does everything to order. I gave him all my specs and he built a set for my 56 Packard that fit snug on the inside and was a perfect hub centric for my wheels. A few mic measurements and he will build and ship them. They are a bit pricey but I felt safer than some crappy eBay ones. Put 1k miles on them and no issues.
12-27-2017, 01:07 PM | #7 | |
12-27-2017, 01:15 PM | #8 |
Same problem as OP here. Also running a BFspacer.
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
12-27-2017, 04:09 PM | #9 |
Wheel adapter can make a pair for $190. I know factory axles have a center bore of 78.3, but am replacing the axles (old owner had long 73-87 axles in the short 69 rear end so they are barely touching the bearings), so I don't know what size center bore to order yet. I'm going with CPP or Yukon conversion axles if anyone has a set to measure.
12-28-2017, 08:36 AM | #10 |
Bora makes some very nice wheel spacers/adapters. They will make any bolt pattern and width.
1965 C10 LS2/4l70, WHITE, 5/7 DROP LINK TO SUPER SNOOPY C10 BUILD---> http://67-72chevytrucks.com/vboard/s...d.php?t=689283 1977 C10 SILVERADO HAWAIIAN BLUE, 5/5" DROP, LS6/4L80E 1976 CHEVY K5, 350/350, YUBA GOLD/SADDLE |
