Old 12-18-2017, 07:03 PM   #1
jkk
jkk's Avatar
How to remove and install rear glass
Hey guys
Fixing to install one piece rear glass in my truck. Need advice on first how to get the slider window out then best way to install the new one piece glass or would it be "safer" to take it to a glass shop don't want to break it.
jkk is offline   Reply With Quote
Old 12-18-2017, 07:17 PM   #2
mongocanfly
Post Whore
mongocanfly's Avatar
Re: How to remove and install rear glass
its fairly simple..I've done several by myself with no issues...remove the chrome locking strip and use the plastic tool to get under the glass, working your way around and it'll roll right out...I bet utube has a video on it...
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 12-18-2017, 11:34 PM   #3
bilfman
bilfman's Avatar
Soapy water or wd 40 is also your friend.
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205
1971 GMC 3/4 Ton 4X4
bilfman is offline   Reply With Quote
Old 12-19-2017, 10:48 AM   #4
RotaryRocketeer
RotaryRocketeer's Avatar
Just out of curiosity, why do I see everyone ditching the sliding rear glass? I kinda like mine...
RotaryRocketeer is offline   Reply With Quote
Old 12-19-2017, 10:58 AM   #5
TKCR
TKCR's Avatar
Here's a few YouTube videos on the subject:
https://www.youtube.com/results?sear...uck+rear+glass
Old 12-19-2017, 11:42 AM   #6
Rich84
Rich84's Avatar
I like mine too..No A/C in my truck. I have an electric one in my 2016 Silverado.
Rich84 is offline   Reply With Quote
Old 12-19-2017, 11:54 AM   #7
Man With A Gun
Man With A Gun's Avatar
I've had problems in more than one truck where the felt padding under the glass that slides gets all bunched up and the window won't close, leaving your vehicle unsecured.
When I finally get that problem solved I never use the slider window again for fear it will happen again.
Other reasons:
Appearance
Blocks view a little bit
Easier to break into
Leaks when wind-driven rain gets in (I'm in FL on the Gulf Coast)
Costs more
I always have ac so don't need it for cab ventilation
77 Chevy K20 Longbed
86 GMC C3500 Dually
07 Silverado 2500HD
All standard cabs
Man With A Gun is offline   Reply With Quote
Old 12-19-2017, 12:08 PM   #8
novice
Little off subject... has anyone installed the flush rear glass conversion from "one piece glass"?
novice is offline   Reply With Quote
Old 12-19-2017, 12:21 PM   #9
RotaryRocketeer
The headache rack on my flatbed takes care of the security issue. Usually leave the sliding glass open when parked if it's nice outside. If they want the truck bad enough to break the welds on the frame and remove the bed, they deserve to have it.
Old 12-19-2017, 10:34 PM   #10
Hiluxxulih
Hiluxxulih's Avatar
I I just used some heavy gauge electrical wire when I just did mine .
1985 Chevrolet Custom Deluxe
4x2 , 305 v8 , 700R4 transmission
Hiluxxulih is offline   Reply With Quote
Old 12-20-2017, 12:16 AM   #11
TrailerTrash
TrailerTrash's Avatar
heres some good tips
http://forum.73-87chevytrucks.com/sm...?topic=15999.0
- When the Reaper makes his deal, trust in your steel -
'77 C10 350/350 2/4 drop and a mild street engine
TrailerTrash is offline   Reply With Quote
Old 01-01-2018, 01:28 PM   #12
4x4chase
I'm going the opposite direction with mine. I'll be installing a slider. Anybody need the one piece rear glass?
4x4chase is offline   Reply With Quote
Old 01-01-2018, 02:47 PM   #13
jkk
jkk's Avatar
What year is your glass
Old 01-01-2018, 08:18 PM   #14
Pontiac1976
Pontiac1976's Avatar
Most time if it's old rubber takes about 10 to 12 min take out the back glass and the plain flat glass is faster to get out. So you do not have to break the glass to get in.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 01-02-2018, 11:01 AM   #15
4x4chase
Originally Posted by jkk View Post
what year is your glass
1984
Old 01-03-2018, 09:24 AM   #16
riz
I'll take it ! I'm ditching my slider too for security reasons...condition?
RIZ
81 C10 short box
82 K5 Blazer
riz is offline   Reply With Quote
Old 01-08-2018, 12:03 PM   #17
4x4chase
PM me
Old 01-08-2018, 06:33 PM   #18
Dayton601
Dayton601's Avatar
I was watching one of those youtube videos on the link above, man the guy with the red truck was brutal with that screw driver, looks like a dent each time he pried on it,
Dayton601 is offline   Reply With Quote
