Gas Cap Differences
Hi -
I need a new locking gas cap for my 70. I see there are ones for 70 and earlier, 71 and 72. Whats the difference? I do not think I have the big vent line running up the B pillar on the passenger side and my current cap looks like the 71/72 cap. I'm thinking its the difference between vented and non-vented and I should go with the same style cap i have.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
Re: Gas Cap Differences
The filler necks are different sizes, so there are two different size gas caps.
For sure? But I have a 70 with a 71/72 cap...
![]() Join Date: Jul 2001
You sure your in-cab is the original? Lots of tanks get changed over the years due to rust out. Look for the vent tube on the right hand side of the tank. '71 and '72 both had EEC style tanks.
I moved my tank to under the bed behind the rear axle on my '71 4x4. Weight helps a bit with traction. I still have the locking gas cap I used for the original tank if you can't find what you need. Doesn't fit my current fuel filler as it is a newer threaded style.
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
#5 | |
