Old 12-20-2017, 05:25 PM   #1
Mains52
52' Suspension question!!!
Alright so a lot of you know I am going from a 3600 to a 3100. My 3100 frame is bare right now so I cant move it around the garage very well. Will the 3600 suspension bolt up to the 3100 frame? Also when I do a drop axle on the front can I just rebuild the current spindles with new king pins or do I need new spindles to? Thanks guys
Mains52 is offline   Reply With Quote
Old 12-20-2017, 05:28 PM   #2
mongocanfly
Post Whore
mongocanfly's Avatar
Re: 52' Suspension question!!!
the frames a different I think..if I remember right I think one is straight and one is tapered..but its more about the distance between spring pads on the two frames..
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 12-20-2017, 05:35 PM   #3
mongocanfly
Post Whore
I think these are right...
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 12-20-2017, 06:04 PM   #4
Mains52
Thanks Greg,
I knew the frames were different and all that but I was just wondering if the stuff would line up I guess Ill just have to measure it up because I can't read the numbers on those pics haha
Old 12-20-2017, 06:10 PM   #5
Mains52
According to the diagram I found on the Jalopy Journal the front springs are the same distance and the rears are different.
Old 12-20-2017, 09:32 PM   #6
mr48chev
mr48chev's Avatar
Unless you need to roll it out on the gravel driveway a simple wood framed stand/cart with casters on it would let you roll it around by yourself and it would roll out of the way.
I've seen a lot of inexpensive and imaginative setups for moving a frame around. I don't have a photo but I saw one where the guy bolted legs to the frame using existing frame holes with casters on them. That would make it rough to work on it in that area though.
My ongoing truck projects:
mr48chev is online now   Reply With Quote
Old 12-20-2017, 09:58 PM   #7
joedoh
joedoh's Avatar
I have tack welded an axle to a frame make it a roller before. just roll it under, tack tack. done.
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
