12-20-2017, 05:27 PM | #1 |
Old member
Boss wheel mod question
I posted this on the other thread but decided to make my own.
The fronts all have that small problem of the hubs not clearing the center caps with the O rings. We all know a little grinding is all you need for it to work which is no biggie since we all want a custom wheel for these trucks. The rears should be fine with nothing to do but swap caps right. My question is this thoe? I like the new Chevy bowtie centers that they use on the Tahoe's and suburbans. They are flat though. So could you get a flatter dust cap for the hub and say a 1/4" wheel spacer to install the centers and it not rub anything. Has anybody tried this and know for sure if it would work.
12-20-2017, 06:03 PM | #2 |
Old member
Re: Boss wheel mod question
Went out and popped the boss cover off. It would take at least a 1" spacer to clear the hub dust cover as is. So I don't think it would work.
