Old 12-20-2017, 10:03 PM   #1
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Darn it anyhow, more front suspension questions - disassembling the control arms
See picture and captions. Any input appreciated. Thank you
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 12-20-2017, 10:26 PM   #2
Richard2112
Richard2112's Avatar
Re: Darn it anyhow, more front suspension questions - disassembling the control arms
Those caps will often have a spot weld on them. Mine did. And the pivot bar will turn some number of rotations on threads that will shift the center.
You can adjust those before install for more or less caster but I think the pivot bar is usually centered same number of turns and both sides (driver and passenger) are set the same.
Richard2112 is offline   Reply With Quote
Old 12-20-2017, 10:30 PM   #3
jessemthompson
I have not tackled this job as of yet, but I know they are not pressed on. It does take some grunt to get them off though. I’ve seen a picture of one that someone rolled over with their tire and then removed it.
jessemthompson is offline   Reply With Quote
Old 12-20-2017, 10:38 PM   #4
FirstOwner69
FirstOwner69's Avatar
The service manual is your friend. It has a good description of the removal process and how to re-center the shafts. Torque values are also near the end of the manual.
http://67-72chevytrucks.com/vboard/s...d.php?t=558016
FirstOwner69 is offline   Reply With Quote
Old 12-20-2017, 10:42 PM   #5
Grumpy old man
Grumpy old man's Avatar
If your sending them out for powder coat you assemble them after, this should help .
http://67-72chevytrucks.com/vboard/s...d.php?t=599579
Grumpy old man is offline   Reply With Quote
Old 12-21-2017, 12:02 AM   #6
71CHEVYSHORTBED402
Yep, I see a very tiny spot weld on the cap I tried to remove. I clean em up and pull the caps off.
The upper control arm pivot bar ("shaft") does a 180 with a little more play. The lower one turns 360 degrees, but still only fits one way. But you said "rotations", so I'm probably way off. I'll now more with the caps off.
Very cool, sometimes I forget about that manual. Frustrating to read on occassion, especially when you find out it's not there.........HA!
Definitely and thread noted. I'm going through it now, there's a lot of good info.
I didn't know to count turns when I removed the steering linkage, but I measured the thread exposed from the couplers, and the lengths. I figured I'd just buy grease seals for the existing tie rods. But now you have me wondering if new tie rods are more better. Old ones look great, but........
Tony
Old 12-24-2017, 01:34 PM   #7
71CHEVYSHORTBED402
I knocked off the weld on one. Nothing. I take it you have to cut the bushings out first?
Any thoughts on new control arms already built? Are good ones available?
Tony
Old 12-24-2017, 03:45 PM   #8
Lanman1972
Lanman1972's Avatar
My winter project, so I'm in.
1972 C10 Custom Deluxe LWB, 402/400, PS, PB, A/C, Highlander, Hugger / White
1971 C10 Cheyenne LWB (SWB), 350/350, PS, PB, A/C, Dark Olive / White.
Lanman1972 is offline   Reply With Quote
Old 12-24-2017, 04:18 PM   #9
FirstOwner69
I'm not sure how you could cut them without damaging the control arms. The bushings are steel and have both outer and inner threads. The outer threads engage the control arms and the inner threads engage the shafts. This allows the control arms to be shifted fore and aft. I get confused with the alignment terms, but I believe that's the caster adjustment. You may want to consider buying a 3/4" drive socket set if you don't have one. I bought one at Harbor Freight that's fine for occasional use. Then get a long cheater and have at it.
Old 12-25-2017, 09:33 AM   #10
weq92f
weq92f's Avatar
I swapped my bushings/caps/shafts out using nothing more than a big pipe wrench. No welds found on there but they had been done at some time in the past ( not factory fresh ).
Hth,
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 12-25-2017, 12:24 PM   #11
Steeveedee
Who Changed This?
Steeveedee's Avatar
John Armstrong is your friend. Or use a decent impact wrench. After being on there that long, and having been given a serious torquing at the factory, they are tight. But they will unscrew the entire way.
~Steven
Simi Valley, CA
Steeveedee is offline   Reply With Quote
Old 12-25-2017, 03:20 PM   #12
71CHEVYSHORTBED402
You guys helped a lot. After I cut any spot welds, I soaked it up with penetrating oil, heated it up good on the inside and out with a heat gun, and used a big pipe wrench and big pipe.....BINGO!
The pipe was the ticket. BFH on the pipe wrench wouldn't do it. Thank you.
Tony
Old 12-26-2017, 12:33 AM   #13
Steeveedee
Who Changed This?
Steeveedee's Avatar
I love the smell of penetrating oil in the morning. Smells like...VICTORY! I have an 18" breaker but we still had to put a cheater bar on the thing, plus have my 270 pound son stand on the lower control arm while I worked it. It kept tipping him up, and since we were doing it in the side yard, we got greasy hand prints on the wall of the garage. We should have broken those loose under the truck, but we didn't realize what a job it was going to be before that. I've rebuilt many a front end over the years, but this one was a real workout. My first truck front end overhaul. FWIW, my 40+ year old impact wrench wasn't cutting it. It used to be able to take (1/2") lug nuts off in either direction, but it's showing its age these days, too.
~Steven
Simi Valley, CA
Old 12-26-2017, 01:48 AM   #14
71CHEVYSHORTBED402
I had the control arms in the vice, and employed my 220 lb. son to hold one while I pulled the nuts off.
I still have to hit the lowers, but I can now say the "hard part" part is cleaning. Lot of grease built up over 45 years, it's a dirty job.
Tony
Old 12-26-2017, 01:51 AM   #15
RedRider
RedRider's Avatar
You're making some good progress, thanks for the great documentation.
1970 C-10 "Old Yeller"
RedRider is offline   Reply With Quote
Old 12-26-2017, 09:05 AM   #16
Steeveedee
Who Changed This?
Steeveedee's Avatar
Yeah, mine were in no danger of rusting, either, with 45 years worth of grease built up on 'em.
~Steven
Simi Valley, CA
Old 12-26-2017, 09:31 AM   #17
notsolo
notsolo's Avatar
On Reassembling the bottom especially, 2 dimple holes up on control shaft and angled to about where they will bolt back on the cross member, align the control shaft in the 2 holes on either side of lower control arm, put the screw caps on either side, just starting the threads. Match the number you put on each cap as you thread them into the control arm and onto the shaft. There is a thread on here that may explain it better.....Ed.
notsolo is offline   Reply With Quote
Old 12-26-2017, 04:38 PM   #18
71CHEVYSHORTBED402
That's good advice.
Unless I'm missing something, the old lower shafts have just one of those holes, at least mine just have one, and they're original. I think the replacement shafts have two, but the "post" on the rear mount is cut or a different style, so it doesn't insert into the shaft.
I hear the upper shafts adjust. At this point I don't see how the old ones did. To me it appears you set the position, tighten the nuts evenly as you say for the lowers, torque and you're done. Can't speak for replacements, but I'm sure (yikes) there are instructions.
Tony
