Floorboard date code?
I'm in the process of putting my 70 GMC back together. The other night while under the truck I notice what appears to be a date code stamped into passenger side floorboard. It on the outside of the floorboard directly behind where the wheel well is located. The wheel wells are currently out. If they where in I wouldn't be able to see it.
The date appears to be 19 3 1970 Has anyone seen this before? Thanks
1970 GMC 2500 700R Trans, RideTech 4 link rear suspension, air bagged on all four corners, factory upper/lower A-Arms, 2 inch drop spindles. 350 SBC 300hp Weiand Supercharger FiTech 30004 EFI |
![]() Join Date: Jan 2009
Re: Floorboard date code?
My 70 Chevy had numbers stamped into the same location on the floorboard. I thought they were part numbers for the individual pieces of sheet metal that make up the floorboard. I will have to look again now.
![]() ![]() ![]() Join Date: Oct 2015
My 71 K1500 has a date stamped in that location.
1972 Blazer Highlander 1971 GMC K1500 SWB (sold) 2004 Corvette Z06 CE |
![]() Join Date: Feb 2011
My 70 GMC had this in the bed towards front cab.
MusicMan70 1961 GMC Suburban |
