Old 12-22-2017, 12:01 PM   #1
usdcrs
55 Fuel Tank Question
This is my first post here and hope I am not repeating old convos. I have a 1955 Chevrolet pickup that has had the drivetrain from a early 90's full size Chevrolet pickup. They mounted the fuel tank for the donor truck in the bed. I am assuming so they could use the original fuel pump and lines for the throttle body fuel injection. I am looking at putting a 69 Mustang tank under the truck. Is it feasible to cut out the part of the fuel tank I have where the pump mounts and have it welded into the Mustang tank so that everything will work without much modification? I don't know if it matters but the truck is running Dakota digital gauges. Thank you in advance.
usdcrs is offline   Reply With Quote
Old 12-22-2017, 12:43 PM   #2
Speedbumpauto
Speedbumpauto's Avatar
Re: 55 Fuel Tank Question
NO! Cutting or welding on a used tank is a good way to die, although there are "cheater" way to try It in extreme circumstances. Many aftermarket tank people make the tanks with provisions for in tank pumps. I used Tanks Inc.
Speedbumpauto is offline   Reply With Quote
Old 12-22-2017, 04:16 PM   #3
usdcrs
I was going to purchase two new tanks to Frankenstein together. I will check out your suggestion. Thank you.
Old 12-22-2017, 06:00 PM   #4
my56chevytruck
my56chevytruck's Avatar
I was going to say something like that, but that being said, I'd agree and say please dont' do that.
RUBBER DOWN AND HIT THE ROAD!!!
1940 Ford Dlx Coupe
1969 Mach1
my56chevytruck is offline   Reply With Quote
Old 12-22-2017, 11:41 PM   #5
bosco
bosco's Avatar
I have a Mustang tank under the bed, with an external fuel pump. Currently running a carb, so when I make the jump to fuel injection will have to replace the pump with a high flow pump, but an easy swap.
bosco is offline   Reply With Quote
