Towing question.
I have a 2wd and thus, no holes for tow hooks. If my truck needed a tow, would it be safe to attach a tow strap ("snatch strap") around the front bumper, as close to a frame horn as possible?
If a brush guard was on my front, would it be safe to do the same thing from there, where the guard attaches to the front bumper? |
![]() Join Date: Aug 2004
Re: Towing question.
I have put a strap around the v-shaped front cross member. Worked well and no worries about bending anything.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
I could see that working, might be hard to get under that far though...
![]() Join Date: Mar 2003
Do not go putting straps around x-members---that is how they get bent. If you need an attachment point install a hook or build an appropriate bumper
I have seen hooks welded or bolted on the bottom of the guard where it is attached to the bumper.
Always pull from a point on the frame rail, same as tow hooks. I have seen 2wds drilled for tow hooks. You can drill your frame for tow hooks. If you use a brush guard it will interfere with frame mounted hooks, so mount hook to guard. But it's best to weld a tube between uprights/mounting plates. I've seen them bend right in from a hook being pulled
If possible I would use the lower A-arm. Do not pull on the cross members.
1972 K10 4" lift, 35’s, 383 stroker, 700r4, current project. 1971 C10 3"/5" static drop, 355/350. "La Bamba.” The current daily driver. |
