12-23-2017, 11:56 AM | #1 |
Pros and cons of closing your cowl area
What are the reasons not to weld up the cowl area on our trucks? Seems to me a good way to protect the areas under there that have years of abuse. I can't figure a way to get down in there to seal and protect it and I don't have a use for the vent. I am not using it. So tell me why shouldn't I weld it up.
12-23-2017, 01:36 PM | #2 |
Re: Pros and cons of closing your cowl area
Subscribed
12-23-2017, 01:49 PM | #3 |
You mean where the windshield wipers are.
12-23-2017, 05:38 PM | #4 |
12-23-2017, 06:34 PM | #5 |
Moderator
The cowl panel can be welded up. Why not just the removable cowl panel?
12-23-2017, 07:22 PM | #6 |
12-24-2017, 02:01 AM | #7 |
The windshield wiper motor and arms would be the best reason to have some access to that area. PO welded mine and I had to cut it back out to change the wiper motor and arms out. I wonder if you just use a screen there instead to keep the leaves and pine needles out?
12-24-2017, 07:44 AM | #8 |
Moderator
That's what I plan to do, they male one for the next gen trucks. I was taking measurements for that last night in fact. I'll make a card board pattern first.
12-26-2017, 08:37 AM | #9 |
Brothers sells shaved cowls for these truck my truck has one
Measure with a yard stick Mark with Chalk Cut with a torch Built it yourself, don't count on others to to do it for you or with you. It will never get done |
12-26-2017, 09:21 AM | #10 | |
Moderator
12-26-2017, 09:30 AM | #11 |
i'm doing the smooth cowl and going to make a rubber seal/gasket that sits underneath to keep as much as i can out. i also sprayed a rust undercoat from eastwood down inside everything. It has about a 24'' long hose with and end that sprays in every direction to coat everything real good. did that to all the areas that you couldn't get epoxy primer on
12-26-2017, 03:34 PM | #12 | |
12-26-2017, 05:39 PM | #13 | |
This sounds like a good idea. Anyone have pics of a solid cowl panel installed? |
12-26-2017, 05:56 PM | #14 |
Moderator
12-26-2017, 10:05 PM | #15 | |
