Old 12-23-2017, 03:20 PM   #1
blackhawck
NP205 leak at speedo
I had replied to an old thread about getting the sleeve for the speedometer cable part# AC Delco 326651. Are these things just non existent now? I think I broke google looking for this thing. I ordered a 16x10x4 gasket but has not stopped my leak, I'm having trouble seating it in the sleeve. ANY help on a location for the sleeve would be greatly appreciated. Merry Christmas
blackhawck is offline   Reply With Quote
Old 12-23-2017, 04:23 PM   #2
Mryan
Active Member
Re: NP205 leak at speedo
I found one here https://www.gmpartsgiant.com/
Mryan is offline   Reply With Quote
Old 12-23-2017, 05:08 PM   #3
blackhawck
No luck there, it says discontinued part none available. Is there a new part number or alternate? Someone has to have these somewhere.....
Old 12-24-2017, 11:19 AM   #4
chevy71super
There has been a lot written up on this. I found this: http://www.quad4x4.com/catalog/qu30091. Not sure if it is the right part and is expensive.
71 Cheyenne Super 4X4 SB
72 Cheyenne Super 4X4 SB
72 Cheyenne 4X4 SB
chevy71super is offline   Reply With Quote
Old 12-24-2017, 04:28 PM   #5
blackhawck
Wow! Yeah they are proud of that. Thanks for the link, still trying to see if a rebuild kit would have the seal in it. I'm going to start hitting some transmission shops and ask about a rebuild.
Old 12-25-2017, 02:56 PM   #6
1966 K10
1966 K10's Avatar
This is the seal most are selling for $15-20
http://www.oringsandmore.com/oil-sha...rice-for-1-pc/
I think that is the one you said you already have
1966 K10 is offline   Reply With Quote
Old 12-26-2017, 03:09 PM   #7
El Dorado Jim
please let us know if you find something that works....
El Dorado Jim is offline   Reply With Quote
Old 12-26-2017, 04:17 PM   #8
1966 K10
1966 K10's Avatar
Ive used the seal and it stopped a leak for my Jimmy. One thing to note, check to see if there is a groove or rough spot on the shaft where the seal sits. I polished mine and didnt seat the seal in the same spot where a small groove was. If I set it all the way down it would have leaked.
Old 01-04-2018, 11:50 AM   #9
blackhawck
66 K10, is the seal you referenced a garlock seal? I ordered some that someone had referenced a 16 x 10 x 4 and they are a hard seal with spring imbedded in the lip. I could not get it into the groove of the sleeve. Maybe by heating it?? Does anyone know if the original seal was just an O ring or this type of seal? I still can't believe out of all the NP205 still out there that the ACdelco part would get discontinued.
Old 01-04-2018, 01:20 PM   #10
1966 K10
1966 K10's Avatar
It is a small hard seal, I did not see any spring but didnt cut it open. The original did not have a spring as far as I could tell.
