Old 12-24-2017, 04:15 PM   #1
66redw/white
made in america
66redw/white's Avatar
cpp brake issue
so i did the swap to disc brakes on my 64. wanted to go a little lower and stop a little bit better. so i made the call to the cpp guys. they set me up with all the stuff to get it done. im finished now and for some reason my front brakes drag like crazy. ive bled all around there is definitely no air in the system. the master cylinder was bench bled. i dont know what to check next. can yall help?
2005 gmc sierra- 4/6, t56, cammed 5.3. 4.10, big bars, and brakes.
sounds good
1964 c10-283 powerpack, 3 on the tree
2004 corvette- lowered, borla, tuned. slow
my old girl
1966 c10- 305v8, t-5 sold
66redw/white is offline   Reply With Quote
Old 12-24-2017, 04:17 PM   #2
raidmagic
raidmagic's Avatar
Re: cpp brake issue
Proprtioning valve? Drum disk master? Are the fronts hooked to the proper outlet?
raidmagic is offline   Reply With Quote
Old 12-24-2017, 04:19 PM   #3
66redw/white
made in america
Re: cpp brake issue
its a non power disc drum master. everything seems to be properly hooked up. ill post a picture in a second
sounds good
my old girl
Old 12-24-2017, 04:24 PM   #4
66redw/white
made in america
Re: cpp brake issue
sounds good
my old girl
Old 12-24-2017, 05:15 PM   #5
1966 K10
1966 K10's Avatar
Re: cpp brake issue
CPP proportioning valve is a known POS, just wait a few weeks and it will start leaking too.
1966 K10 is offline   Reply With Quote
Old 12-24-2017, 10:02 PM   #6
dodgiesdad
dodgiesdad's Avatar
Re: cpp brake issue
Based upon your description, I would also have to suspect the proportioning valve. I to had a CPP system it lasted about three months before the valve failed.
dodgiesdad is offline   Reply With Quote
Old 12-25-2017, 12:08 PM   #7
ls60apache
Re: cpp brake issue
guess I will be looking forward to this also havnt ran any fluid thru it yet is there a better one to fit in its place with four wheel disc?
ls60apache is offline   Reply With Quote
Old 12-25-2017, 01:39 PM   #8
rvrfoot
Re: cpp brake issue
I must have got the good one. No problems here 6 months in.Name:  DSCN0822.jpg
rvrfoot is offline   Reply With Quote
