Old 12-24-2017, 06:13 PM   #1
expedition
Dolphin gauge insert
Hi there I got a dolphin gauge set with the aluminium insert for my 64 gmc truck ,not sure how to fit the insert on my original cluster plastic frame .I already cut out the old gauges contour leaving the lip on ,does insert plate mount in front of plastic frame or behind it ? If I install the thick plate plate in front of frame there not much room for the screws to fit in to the dash .Anybody as an idea on this ?Thanks
expedition is offline   Reply With Quote
Old 12-24-2017, 07:21 PM   #2
MusicMan70
MusicMan70's Avatar
Re: Dolphin gauge insert
Greetings and Happy Holidays Expedition!
I'm not sure if the insert will work with that plastic gauge panel.
If so you may want to consider the earlier GMC (60-61)metal panel and add your insert (on top) to that style. Just cut out what you won't need.
This is a Boese Engineering insert.
MusicMan70
1961 GMC Suburban
MusicMan70 is offline   Reply With Quote
Old 12-24-2017, 07:54 PM   #3
expedition
Ok thanks for the reply I see how its done now , the 60-61 metal one might be hard to get ill fart around with what I got and make it work thank a lot
Old 12-26-2017, 02:43 PM   #4
61K10
61K10's Avatar
Let us know how they work when installed. Some people have had some problem with the gauges.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 12-26-2017, 04:47 PM   #5
expedition
My problem is not the gauges per say ,its the thickness of the plate if I installed it in front of my cluster plastic frame ,the plate is kinda thick ,no room for the cluster mounting screw to the the dash ,ill have to plug old holes and drill new ones once the plate is on with gauges ,I see some of the members have this kinda of plate and I was wondering how they installed it that's all .
Old 02-01-2018, 11:13 AM   #6
expedition
Hi there does anyone have a GMC 60-61 instrument cluster backing plate for sale ,ill be interested to purchase or trade ,I like to get this so I can mount my new Dolphin gauges and insert Thanks
