11-01-2003, 07:19 PM | #1 |
Keepin an eye out
one more time brake experts....
I am using later 1 1/4" rotors on '71-72 spindles. I bought loaded calipers for a '71 and max opening w/ pads is 1 1/8" what is the solution here...later calipers? 70 c10 BTW.
1970 Chevy C10 SWB 5.3 1996 Toyota Tacoma SR5 4x4 2007 Vespa GTS 250 Scooter ZIP 91351 |
11-01-2003, 07:33 PM | #2 |
faster, faster, faster
Sounds like you know the A to the Q already. The new calipers are only $10 a piece from the local parts house here, so figure Cali. prices and your looking at $200 a piece. lol
I'm going to Law School, wanna debate? It's good practice. |
11-01-2003, 07:37 PM | #3 |
Fabricate till you "puke"
In the later 70's/early 80's, there were 1" thick rotors. If you are sure that the pistons are all the way back in the calipers, my guess is that you have the wrong parts(that puter screws those parts guys up at times!). Good luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
11-01-2003, 07:54 PM | #4 |
Keepin an eye out
so later calipers bolt up to early spindles? Just want make sure before I go back to the AP store and spend time.
11-01-2003, 08:00 PM | #5 |
i have not run into that "mismatch" of parts, so I cant say for sure if the calipers will bolt(they do list 2 different spindles....1" rotor, or 1 1/4" rotor on the later trucks). The 71-72 however should only be 1 1/4" thick rotors. crazyL
