LMC Power windows relays
Installed the LMC power window relay kit today man what a difference that made in the speed of the windows going up and down well worth the effort.
Re: LMC Power windows relays
Oh really, my widows are slow and was thinking i may need new regulators or motors or both never thought that a relay would change speed
The relays put 12 volts to the motor instead of going through the switch no voltage drop. Best 30 bucks you can spend
One of the best mods you can make .
I would also inspect and grease the tracks and rollers . I did all this and replaced all the felts . The felts were a little tight and slowed it down a little so I sprayed them with silicone spray and that made a lot of difference . So in the end everything needs to be in good working order as well to get the most . I believe my 82 windows are faster that my 06 . As jkk said , the voltage has to go around the world before it gets to the motor . I checked mine before I did all my upgrades and I think there was like 7 or 8 volts to the motor . |
As homemad87 says inspect everything thing as well my felts looked god I greased the tracks as well
