Old 11-01-2003, 07:27 PM   #1
fast71
Drive it like U stole it
fast71's Avatar
msd 6al ?
Me and a friend are building a s10 with a small block well we were going to fire the motor a little while ago but we're not getting fire . we ran the test that is in the directions of the 6al box and got no results which by them means the box is bad . I pulled the dist. out and turned it by hand . I can hear the boxed making a clicking noise but no signal at the neg. side of the coil.
with the ing. switch on I have power at the pos.side of the coil and a constant ground at the neg side of the coil ,even when spinning the dist. . I thought the neg side was a pulse side . Does anyone have any Ideas?
Brian
71 custom 10 swb
72 nova ss
72 nova custom
87 s10
96 burb
94 camry
53 5 window 3100
fast71 is offline   Reply With Quote
Old 11-01-2003, 07:43 PM   #2
stelth2002
Young Gun wth Fast Inline
stelth2002's Avatar
I have one on my truck and from the sounds of it, its bad. I plugged mine in and it worked excellent. I could weld with it if i wanted.
1967 Chevrolet LWB with built 292! 415 ft. lbs of torque, 4 speed :O with 27% overdrive too, 3.73 Posi. Frame and body done... getting painted!!!
stelth2002 is offline   Reply With Quote
Old 11-02-2003, 01:49 AM   #3
Chevy67Tk
Chevy67Tk's Avatar
The MSD 6 series pulses very fast, if you were using a digital volt meter they will not respond fast enough to detect the drop of the ground and I doubt you will even see it on an analog meter because it is trying to fire multiple sparks. You might want to check the coil by checking the resistance across your coil, and double check you’re wiring. Before you go sending it back
Chevy67Tk is offline   Reply With Quote
Old 11-02-2003, 10:55 AM   #4
fast71
fast71's Avatar
We have gone through the wiring till I'm blue in the face. we're going to try another box today . I'm almost positive that it is the problem . My buddy went to a msd trouble shooting site last night and found the same problem we're having and it said replase box so I ordered another one from Advance auto parts and going to try it . I will update later today.
71 custom 10 swb
72 nova ss
72 nova custom
87 s10
96 burb
94 camry
53 5 window 3100
Old 11-02-2003, 11:09 AM   #5
rage'nrat638
rage'nrat638's Avatar
pull the cap and turn the engine over,, may sound stupid but make sure the rotor is turning
rage'nrat638 is offline   Reply With Quote
Old 11-02-2003, 11:15 AM   #6
fast71
fast71's Avatar
we did that and we took the dist out and turned it by hand and still no spark .
71 custom 10 swb
72 nova ss
72 nova custom
87 s10
96 burb
94 camry
53 5 window 3100
Old 11-02-2003, 12:10 PM   #7
bigjimzlll
bigjimzlll's Avatar
Run the ground wire back to the battery
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 11-02-2003, 12:10 PM   #8
my new 72
faster, faster, faster
my new 72's Avatar
Mine kinda hums. I put it inside the cab under the A/C box and the firewall and I may put it back in the engine compartment. No stereo in the truck right now, so I hear it the whole time I drive. Maybe I'll just get some speakers and install the stereo.
I'm going to Law School, wanna debate? It's good practice.
my new 72 is offline   Reply With Quote
Old 11-02-2003, 02:50 PM   #9
fast71
fast71's Avatar
installed new box fired right up no problems . I guess we got a bad one right of the box
71 custom 10 swb
72 nova ss
72 nova custom
87 s10
96 burb
94 camry
53 5 window 3100
