Senior Moment
![]() Join Date: Mar 2002
Heater Hose ?
On a 71 Non AC truck. which heater hose goes where ? Does the top one comeing out of the firewall go to the rad or the intake?
I forgot to note it when I took them off. Thanks in advance
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2019 GMC Diesil Dually. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 |
Inline 69
here ya go........jeff
Formerly yellow72custom
Crap.....looks like mine are on backwards!
Also...which end of the heater core is supposed to be on the top on a V8 truck? I think the big end is on the bottom of mine...i may have to go check though.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride. '70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck. '97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg |
Senior Moment
Humm....i think mine is on the bottom....so it should be OK. Would the air flowing through the heater core backwards give me bad heat? My heat works OK....but not great considering i have a one year old core and blower motor.
jef5150,
Which book did that pic come from.........? Don't believe I've ever saw a heater hose going to the radiator before.....
1970 Chev CST 2003 Harley Fatboy 1975 Chevrolet Step Van 1956 Chev Bel Air 1977 Blazer 2WD For Sale $3000.00 1978 Blazer 2WD For Sale $7000.00 1978 Silverado 2005 Monte Carlo |
Guest
Posts: n/a
There was a thread started about the topic of the heater hose going to the radiator. Check the search and see what comes up. I cant remember what the outcome of it was....
Guest
Posts: n/a
Last Thread Next Thread
Author Thread Cap'n Hook Member Registered: Jun 2003 Location: Texas Hill Country Posts: 38 Q: New radiator, but no heater hose nipple! Gotta new 4-core radiator for the Jimmy from PartsAmerica but there's no prevision for the return heater hose. Can I just run it back to the water pump, instead? Thanks guys, and great forum! __________________ Jason Report this post to a moderator | IP: Logged 08-24-2003 05:50 PM adamls Gotta Startem Early Registered: Oct 2001 Location: Amarillo, TX, USA Posts: 293 Contributor No, the water needs to make a complete circle that goes through the engine and then through the radiator. If you send it right back into the pump then it will never cool off. __________________ 67 SWB In Progress, one piece at a time, maybe 3 years I will be finished Report this post to a moderator | IP: Logged 08-24-2003 05:57 PM Cap'n Hook Member Registered: Jun 2003 Location: Texas Hill Country Posts: 38 So, then how do I get this back to the tank? Do I need to go have a new nipple fitted to the new radiator for this hose? Guess I know why I only paid $150 for this thing now! __________________ Jason Last edited by Cap'n Hook on 08-24-2003 at 06:17 PM Report this post to a moderator | IP: Logged 08-24-2003 06:02 PM tom hand CCRider Registered: Feb 2000 Location: Olive Branch,MS,USA Posts: 1854 Yes you can run it off the intake and back to the water pump...that's how mine was run from the factory. I have never seen a 67-72 that had the nipple on the radiator from the factory, I aways thought that was a 73 up thing,[and the radiator will bolt right in] but these trucks were built at several different places so there is no telling __________________ 72 GMC Sierra SWB almost finished---- 84 Softail Olive Branch MS Report this post to a moderator | IP: Logged 08-24-2003 06:21 PM 68 Stepside On the Road Registered: May 2000 Location: Central Illinois Posts: 3464 I agree with Tom. Millions of GM cars/trucks have one hose running to the pump, and the other to the tank. You should have no problems doing it that way. __________________ TJ --67-72Chevytrucks.com Staff ------------------------------------- 68 C10 SWB Step 92 Buick Roadmaster The avenues to death are numerous and strange. -- Poe I thought I was her daddy, but she had 5 more. -- Johnny Cash, Cocaine Blues. R.I.P. Report this post to a moderator | IP: Logged 08-24-2003 06:31 PM Cap'n Hook Member Registered: Jun 2003 Location: Texas Hill Country Posts: 38 Ya'll are confusing me! Ok, the intake is already used to feed the heater core, and the return line was going back to the radiator, directly from the heater core. Now this new radiator doesn't have a prevision for this return line from the heater core, so I was gonna run it to one of the two holes in the water pump, one being on top and the other on the passenger side of the water pump, using the latter of the two! Seems to me, once the thermostat opens up, all the coolant will be cooled!? Yes/No? __________________ Jason Report this post to a moderator | IP: Logged 08-24-2003 06:35 PM tom hand CCRider Registered: Feb 2000 Location: Olive Branch,MS,USA Posts: 1854 Yes run it to the hole on the passenger side of the waterpump it will work fine...this is for the heater it has nothing to do with cooling the engine __________________ 72 GMC Sierra SWB almost finished---- 84 Softail Olive Branch MS Report this post to a moderator | IP: Logged 08-24-2003 06:49 PM Cap'n Hook Member Registered: Jun 2003 Location: Texas Hill Country Posts: 38 Just a question, but then why did the radiator Im replacing have the return heater core hose running to the radiator? Maybe a wrong replacement radiator previously, or something of the nature? And I'll be picking up some new parts tomorrow, including the thermostat housing, thermostat and upper and lower radiator hoses, and the bung to fit the water pump for the return heater hose! Im thinking 195 degrees is a bit too hot to run here in Texas summer heat, but 160 is too cool for winter. So I'm gonna pickup a 185 thermo! These have to be the original thermostat housing and metal upper radiator hose, cuz they both have rusted pieces inside them, some pieces bigger than my small finger nail! __________________ Jason Last edited by Cap'n Hook on 08-24-2003 at 07:03 PM Report this post to a moderator | IP: Logged 08-24-2003 06:59 PM jef5150 "Grind -n- Gears" Registered: Apr 2003 Location: stockton,california Posts: 540 Contributor did you order the correct radiator???????????? manual tranny and auto tranny radiators are hooked up differently,,,,,,,,,,,,,,,,,,,,,,,,,, __________________ This is what i do to support my "chevy" habitwww.bzmfg.com/specialprojects.htmlthere are a few MPGs of our equipment! Report this post to a moderator | IP: Logged 08-24-2003 07:00 PM FRENCHBLUE72 Senior Member Registered: Dec 2002 Location: GRANTS PASS OR Posts: 1616 It seem's to me the truck's with automatic's had the hose going to the radiator and manual's had the water pump action going.. But I could be way off base. __________________ 72 BLAZER 4X4 DAILY DRIVER 72 C/10 LWB 2WD FOREVER A PROJECT=454 TH400, painted frame and suspension, lined bed,SO FAR 82 TOY 4X4 350 TH350 ,EXO-CAGE.OLIVE DRAB AND 35'' CLAWS 97 HONDA CIVIC EX LOWERED ,WIFE'S RIDE 69 CHEVY 1/2 TON LWB PROJECT TRUCK. Report this post to a moderator | IP: Logged 08-24-2003 07:03 PM Solver Senior Member Registered: May 2000 Location: Storm Lake, Ia Posts: 495 Most of the trucks I have had the radiator had a port on it for the heater. The aftermarket radiators I have ordered do not have this port on them now.I wonder if anyone makes it that way anymore.I have had to use the spare port on the water pump.That plug on the water pump is kind of hard to unscrew after 30 some years __________________ 1972 Cheyenne Super 20 LWB 1972 Cheyenne Super 10 LWB 1972 Cheyenne Super 10 LWB 1971 Cheyenne Super 10 LWB 1971 Cheyenne 10 LWB 1971 Cheyenne 20 Longhorn 1969 Custom 10 LWB 1968 1/2 ton lwb to be swb 1967 Chevrolet CST LWB Report this post to a moderator | IP: Logged 08-24-2003 07:07 PM Cap'n Hook Member Registered: Jun 2003 Location: Texas Hill Country Posts: 38 Supposedly this is the radiator for my application, AT with A/C! Didn't really pay attention to the heater hose bung not being there in the picture before I ordered! __________________ Jason Report this post to a moderator | IP: Logged 08-24-2003 07:07 PM jef5150 "Grind -n- Gears" Registered: Apr 2003 Location: stockton,california Posts: 540 Contributor you might of ordered the wrong type they are routed differently.........jeff jef5150 has attached this image: __________________ This is what i do to support my "chevy" habitwww.bzmfg.com/specialprojects.htmlthere are a few MPGs of our equipment! Report this post to a moderator | IP: Logged 08-24-2003 07:28 PM Hotrod70C10 Senior Member Registered: Dec 2002 Location: Oklahoma Posts: 709 That's interesting! I've got the typical v8 manual trans hose setup on mine. It is a factory 350 w/ th-350 tranny. I'm guessing the radiator was replaced some time ago before I bought it though. __________________ 70' C-10 LWB Fleetside, 350/350, Edelbrock 1406 600cfm carb, Performer intake, B&M Street & Strip shift kit, HEI, Early Classic 1.5" front and 4" rear drop springs, Mcgaughy's 2.5" drop spindles / disc brake conversion, BF Goodrich Radial T/A's 255/60/15 front, 275/60/15 rear. Report this post to a moderator | IP: Logged 08-24-2003 09:01 PM JimKshortstep4x4 Senior Member Registered: Jul 2001 Location: Kentwood,MI,USA Posts: 1782 My radiator repairmen tells me that he has seen the nipples on the radiators mainly on vehicles with AC. It also makes sense that automatics could benefit from the return being in the radiator. If it were my vehicle and it had air, I would want the nipple on the radiator. Jim Report this post to a moderator | IP: Logged 08-25-2003 07:39 AM Bill72BB Thats the Hillbilly way Registered: Jul 2001 Location: Torrance,Ca Posts: 2573 When I ordered mine it had the return to the radiator , it was a Modine . __________________ BILL Torrance Calif 90504 Member DUF Club Member Old Farts Club 72 3/4ton Custom Camper BB402/400 trans Dynomax Cerama-coat headers , Hei distributor ,Edelbrock 1406 air,ps,pb,leafsprings ,98 chevy 60/40 seat,S10 shoulder belts tilt,3.54 Dana 60 rear. 16" Eagle wheels with LT265/75 16 tires,Gaylord Lid " If I knew I was going to live this long I would have taken better care of myself " Marriage changes passion...suddenly you're in bed with a relative. A GUY'S PRAYER.... Lord, I pray for a nympho with huge boobs who owns a liquor store and likes to fish and hunt and has a Harley .Amen Report this post to a moderator | IP: Logged 08-25-2003 07:59 AM adamls Gotta Startem Early Registered: Oct 2001 Location: Amarillo, TX, USA Posts: 293 Contributor Now, I am confused. __________________ 67 SWB In Progress, one piece at a time, maybe 3 years I will be finished Report this post to a moderator | IP: Logged 08-25-2003 08:11 AM Maximum Overdrive Senior Member Registered: Apr 2000 Location: Montana Posts: 1009 I have had a few automatics and none of them had a return line for the heater core on the radiator. Only tranny fluid lines to them. They all had the set up of the heater core hose going back to the waterpump. __________________ "No freeman shall ever be debarred the use of arms..." Thomas Jefferson Report this post to a moderator | IP: Logged 08-25-2003 09:12 AM Alex Senior Member Registered: Jan 2000 Location: Blaine, MN Posts: 718 Mine (no A/C) had the heater hose nipple and I replaced it (2 core) with a 4 core radiator with no nipple so I took it to the local radiator shop to have one installed. I lucked out as the guy did it for free. __________________ '72 C/10 LWB 402/400 Blaine, MN Report this post to a moderator | IP: Logged 08-25-2003 09:21 AM 72c10step No, rubber side down! Registered: Jul 2003 Location: Loudon, NH and Flint/Flushing, MI Posts: 341 I bought a replacement radiator for my truck a month or two ago. It came with the heater line fitting on it, as well as the tranny cooler line fittings. The old one I removed had the same setup. My truck has a 350/AT and no A/C. Now only if I hadn't dropped the old Voltage Regulator, which put a pinhole leak in the brand new radiator. Doh! 72c10step has attached this image: __________________ Jay -1972 Chevy C-10 Shortbed Stepside (in storage for the winter) -1994 Saturn SL (246,500 mile daily driver/parts hauler) -In my senior year as an ME student at Kettering University Report this post to a moderator | IP: Logged 08-25-2003 11:04 AM Cap'n Hook Member Registered: Jun 2003 Location: Texas Hill Country Posts: 38 Well, my Jimmy has A/C and auto and Im gonna try rerouting the heater core return to the water pump and see what she does. I figure it being a 4-core and all, it will probably cool just fine. Also, Im getting a lower degree thermostat to compensate for the higher volume of water going thru the water pump now! __________________ Jason Report this post to a moderator | IP: Logged 08-25-2003 02:10 PM dubie If the trailer's rockin.. Registered: May 2000 Location: Flin Flon, Manitoba, Canada Posts: 3993 I just went through this exact same thing on the board a few weeks back. You can route the one through the intake and the other goes in through your water pump plug. I have seen both automatics and manual trannies with this exact same setup. It will work!! __________________ "When people ask me why I write such gross disgusting stuff, I like to tell them I have the heart of a little boy..................and that I keep it in a jar on my desk Stephen King Trying to turn a 30 year old wreck into HELL ON WHEELS!!! Report this post to a moderator | IP: Logged 08-25-2003 02:15 PM smitty62 Senior Member Registered: May 2002 Location: North Carolina Posts: 277 (A) Modine still makes the radiator with a nipple. (B) OK to feed back into the water pump--no biggie! (C) If you really want the nipple, take it to a radiator shop--(cheaper than return shipment if it was shipped to you) __________________ Smitty '68 SWB Stepside SHORTSTEPS RULE!! (There's no foreign vehicles in MY driveway) Report this post to a moderator | IP: Logged 08-25-2003 02:29 PM busterwivell Senior Member Registered: Jan 2002 Location: Sahuarita, AZ USA Posts: 1139 I didn't have a fitting in the radiator I took out, but did on the new 4 core I got at Pomona. Just got a cap for it and secured it with a hose clamp. __________________ Bill - Tucson, AZ 47 Chevrolet 2 dr sedan 56 Studebaker 2 dr Wagon 66 Chevelle 2 dr 4 speed 71 C30 Longhorn 86 Monte Carlo SS 96 Tahoe IM - BUSTERWIVE@aol.com Report this post to a moderator | IP: Logged 08-25-2003 03:47 PM Dusti Member Registered: Jul 2002 Location: Washougal WA Posts: 154 Radiator I had to go check what was in my truck,some previous owner replaced the original one with 1 that has the nipple on the radiator that is blocked off and has the conections for auto tranny lines that are not being used since its a 4-speed. Just adding more to the confusion Bob W __________________ 70 stepside longbed Dusti's truck 69 3/4 ton W/292 6cyl Bobs new truck Report this post to a moderator | IP: Logged 08-25-2003 05:02 PM jef5150 "Grind -n- Gears" Registered: Apr 2003 Location: stockton,california Posts: 540 Contributor ac?????????????? quote: -------------------------------------------------------------------------------- Well, my Jimmy has A/C and auto -------------------------------------------------------------------------------- you should of told me that in the begining,,,,,,oh well,now you know how to hook up the a/c,,,,,jeff jef5150 has attached this image: __________________ This is what i do to support my "chevy" habitwww.bzmfg.com/specialprojects.htmlthere are a few MPGs of our equipment! Report this post to a moderator | IP: Logged 08-25-2003 05:26 PM All times are GMT -8 hours. The time now is 07:26 PM. |
nice diagram
nice diagram
David M Proud Owner of A 67 C10 Shortfleet 350/350/3.73 |
its all about the +6 inches
Not that it really matters...as long as it is all hooked up, it'll have hot water in it. Top to bottom, bottom to top, as long as it has hot water and air going through it, you'll get heat.
the heat doesnt work in either of my trucks. and i dont even wanna try and get it to.
70 longbed 496/th400/Ford 9" |
Here is a Pic of how my heater hoses are set up, and it works great
..... Smaller hose to the manifold and the slightly larger hose to the Rad nipple
With a 1972 Chevy Custom-10 Long bed w/350cid th350, (under-construction). Progress on truck so far (follow link): http://67-72chevytrucks.com/vboard/s...ad.php?t=51051 and stage 2 http://67-72chevytrucks.com/vboard/s...ad.php?t=58132 ~ ![]() ![]() Last edited by SEVEND2; 10-05-2007 at 04:54 AM. |
#13 |
SevenD2, mine is routed just like yours, except my lower large hose is going to the water pump.....
#14 |
Firefighter
My old 72 radiator has the nipple in the radiator and so does the new one.
'72 Chevy SWB 350 Auto '67 GMC LWB 350 4 speed '70 Chevy 4x4 Stepside 350 Auto Yellville, Ar. USA ![]() ![]() |
#15 |
Merciless Butcher
This has been a fantastic post..I'm still confused...lol. Any members want to do a recap of what we have learned here. I'm getting ready to do mine next weekend. I'm using Aeroquip hose and fittings ( braided stainless AN-10) and don't want to mess this up. I bought a new heater core and am going to try and sweat copper fittings (3/4") female on the inlet and out. I have a few hundred bucks invested in this and don't want to mess it up.
Your Bought And Sold....I Got Your Soul! |
#16 |
What we've done here is mass confussion.................
#17 |
Inline 69
OK,,,!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
The picture i posted came "directly" from a "factory 1971 chevy service manual"!,That is the way these trucks came from the factory!!!!!!!"Back then",radiators were made in 2 versions,manual or for an automatic(which had a seperate tank in the radiator for tranny lines),either radiator "WILL" work,,,,,,but if your useing an older style that came from an automatic,and put it in a truck that "now" has a manual tranny in it ,you have to plug the 2 openings where the tranny lines usta go..same applys if you switch from a manual tranny to an automatic,the radiator "will" work,but your gonna hafta add an aftermarket tranny cooler to connect the tranny lines to...... To make things even more complicated,most of todays "aftermarket radiators" come universal.So,,,,if you or p/o changed the radiator, or you've switched from a manual tranny to an automatic,or if youve put an "aftermarket radiator" in your truck... those "factory" pics,may be a little different,,,,,,,,,, ,,thats why everyones "set up" is a little different.........Oh 1 more thing,if you changed the motor,or manifold,again the set-up may be a little diferent
#18 |
Firefighter
Yes, those are the same pics I have in my 1972 Service Manual also.
#19 |
Re: Heater Hose ?
How do you mount the Heater Core in the Housing? Does the 5/8" or 3/4" inlet on the Heater Core get mounted on the top? My two heater hoses go from either the Water Pump or the Intake Manifold next to the top Radiator Hose. Any pictures of the correct way to mount them?
#20 |
20' Daredevil (Ret)
![]() Join Date: May 2003
Re: Heater Hose ?
3/4" nipple on top.... this is the water exit from the heater core. Water enters the core through the 5/8" nipple at the bottom.
#21 | |
Re: Heater Hose ?
I thought it was like Radiator. I was going to mount it the other way around so the water flows in from the top and out of the bottom. What would happens the cooling system was not absolutely 100% full, how would the coolant travel up from the bottom to the top of the Heater Core? Would it just sit in there and bubble up? |
#22 |
20' Daredevil (Ret)
Re: Heater Hose ?
Depends, need details on your truck and will probably need to search.... unless it's the same as mine.
Coolant goes from bottom of heater core to top because it's hot.... hot liquid rises same as hot air rises.
#23 |
Re: Heater Hose ?
Thanks, I have 1970 GMC C-20 without A/C.
