Old 12-25-2017, 04:28 PM   #1
jcnelson
Shaved firewall queston
I’m doing a complete frame off restoration and in the middle of smoothing out the firewall. I’ve been through past threads and see a lot of clean beautiful work my queston is the e brake where do you run the cable and the speedo cable
jcnelson is offline   Reply With Quote
Old 12-25-2017, 05:40 PM   #2
harpo231
harpo231's Avatar
Re: Shaved firewall queston
http://67-72chevytrucks.com/vboard/a...1&d=1514237968
Stan
67 swb BLU MULE
posted via flip-fone
harpo231 is offline   Reply With Quote
Old 12-26-2017, 07:17 PM   #3
jcnelson
Thanks for the input but I was kinda looking for ideas or suggestions as to where and what to use to avoid the clutter coming out of the firewall
Old 12-26-2017, 07:24 PM   #4
harpo231
harpo231's Avatar
OK didnt read that
Stan
67 swb BLU MULE
Old 12-26-2017, 07:28 PM   #5
jcnelson
Ya sorry I just reread it and your right I wasn’t very clear. I want the clean smooth look and want to still have them, if I was going buckets I could adapt one between the seats but I plan on a bench seat. Speedo not to worried about it’s the e brake
Old 12-26-2017, 07:39 PM   #6
harpo231
harpo231's Avatar
Someone will chime in .
Stan
67 swb BLU MULE
Old 12-27-2017, 10:17 AM   #7
68Stepbed
68Stepbed's Avatar
It's hard to see, but my speedo cable and ebrake cable came through the same hole just below the column. I removed the ebrake cable and handle assembly when I changed to rear discs, though. I'll eventually do them correctly and reinstall the cable.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 12-27-2017, 09:37 PM   #8
Rod Run
Rod Run's Avatar
You could always go the same route that I am going. Smooth the firewall and use a GPS speedo, that way you don't have to worry about where the cable is going
______________________
www.northeastrodrun.com
Rod Run is offline   Reply With Quote
