12-25-2017, 06:45 PM | #1 |
Ignition switch turning
My complete ignition switch is turning when I turn key to start the truck.How can I tighten to repair?
There's something women like about a pick-up man 1967 c10 swb Stepside 2004 SSR 2013 Silverado swb |
12-25-2017, 07:27 PM | #2 |
Re: Ignition switch turning
Bezel is threaded . turn it to tighten .
Stan 67 swb BLU MULE posted via flip-fone |
12-25-2017, 07:29 PM | #3 |
12-25-2017, 08:22 PM | #4 |
My 67 has a notch in the dash for proper alignment of the switch, keeps it from turning after you tighten the bezel.
12-25-2017, 10:32 PM | #5 |
Does the cylinder need to be removed first? Do I need a special tool to turn?
12-25-2017, 10:41 PM | #6 |
No and No
12-25-2017, 11:07 PM | #7 |
Thanks for the help.
12-25-2017, 11:54 PM | #8 |
Who Changed This?
There is a tang on the switch that lodges in a slot in the edge of the hole that the switch mounts in. It is possible that that tang has worn off, if the switch has been loose for some amount of time. If it is still there, the escutcheon nut will tighten up nicely if the tang is in that slot. There is a spanner made for tightening the nut, but you can use a fabricated one for it. The spanner fits the three indentations on the escutcheon nut.
