12-26-2017, 01:09 AM | #1 |
motor vin
what number do u see ?lmk ty
12-26-2017, 01:25 AM | #2 |
How did I get this OLD!
Re: motor vin
I see 3970010. GM most likely 350ci used from 69 through out the 70's. Probably the most common block.
1967 Oshawa built LWB Fleetside. 327,3 OTT, 515 Vermilion, CST, PS, PB, Shoulder Harness, Tach,Vac, Speed Warning, Choke Delete, Manual Throttle, Fawn interior. Dealer installed A/C 04/2015, N34 Rosewood Wheel 06/2023 Members who I have met personally. Metaldoc, chevnkevin, 62 Longbed, 72LHorn, 72MARIO, YBNORML, TBONE1964, Classic Bowties, Chevemall, Dagnabbitt. |
12-26-2017, 02:10 AM | #3 |
Re: motor vin
That is not a motor 'vin'. That is a casting number used to identify the engine block and typically about when it was made and what is was installed in.
1970 GMC 2500 700R Trans, RideTech 4 link rear suspension, air bagged on all four corners, factory upper/lower A-Arms, 2 inch drop spindles. 350 SBC 300hp Weiand Supercharger FiTech 30004 EFI |
12-26-2017, 07:14 AM | #4 |
Re: motor vin
Look for a stamped number with a three letter suffix.
12-26-2017, 02:27 PM | #5 |
Go Pack Go!
Re: motor vin
Yes, a 010 block is the one to have.
12-27-2017, 06:55 AM | #6 |
Re: motor vin
ok guys where do I find the number on the block to see if it came with this truck,because i am new to this lol . my buddy told me it would also tell me if its a 2 bolt ,or a 4 bolt main .also what color came out first orange or blue lmk thanks guys
12-27-2017, 07:05 AM | #7 |
Re: motor vin
Sorry
12-27-2017, 07:23 AM | #8 |
Re: motor vin
The stamped letters will be on the passenger side front of the block deck... the surface sticks out in front of the cyl. head.
Dad always said, "Son, WISH IN ONE HAND, and ......." -------------------------------------- -------------------------------------- Current toy trucks: '71 GMC 1500 SUPER CUSTOM short/step, orig. dk. blue, 350/700r, ps,pb, A/C '72 Blazer 2wd, ochre & white, 454, tremecTKO 500 5spd. ps, pb, A/C, tilt Last 10yrs of hobby vehicles, had a FEW more in the 50yrs. before these: '66 Plymouth Belvedere City of Miami cop car clone. '70 Nova 406"sb, 13.5-1, solid roller, Brodix, p.glide/t.brake, back halved, 9" Ford, spool 4.88, cage,ladder bar/coilover, 10.5 tire....... SOLD!! '67 C10 short/step side mount spare -- SOLD!! '72 Jimmy 2wd, 350/350, ps, pb, fun driver, lots of bondo & a shiny red paint job..... SOLD!! '69 Nova 350, 4spd, A/C, ps, p.b, ...SOLD!! |
12-27-2017, 07:33 AM | #9 |
Re: motor vin
Not sure when the paint color went from orange to blue, but I have never seen a factory correct motor in a 67-72 truck that wasn't orange. The suffix code or number you are looking for is on the front beck on the opposite side. Looking from the front of the vehicle it will be just under the front of the head on the passenger side. And just so you know. the 3970010 blocks are good blocks. But I have own that block number in both 2-bolt main and 4-bolt main. They a most commonly 4-bolt main with that number but could be either one. Hope this helps you.
12-27-2017, 09:19 AM | #10 |
Re: motor vin
I think blue started in '78? Could be wrong.
12-27-2017, 10:26 AM | #11 |
Re: motor vin
12-27-2017, 03:17 PM | #12 |
Roadtrip!
Re: motor vin
Find the suffix code on the pass side front of engine where the head bolts on. That should narrow it down if the code is still there. As far as a numbers matching vin for a truck, you won't find one. Best you can do is date code the engine and see if it is close. And I think special-K is right on blue engines starting about 78. Orange before that.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
12-27-2017, 03:54 PM | #13 |
Re: motor vin
My 1976 was orange. My 77 was blue. Both we’re Canadian trucks so maybe they were different than USA ones.
12-27-2017, 05:49 PM | #14 | |
Re: motor vin
12-27-2017, 07:14 PM | #15 |
Re: motor vin
Suffix codes.
http://www.nastyz28.com/chevy-engine-code-stampings.php Casting codes and pics. http://www.mortec.com/ |
12-27-2017, 08:25 PM | #16 | |
Re: motor vin
12-29-2017, 10:19 AM | #17 |
Re: motor vin
C8F181490 V0425TDR
You have a discrepancy with your numbers. Your going to need to get the casting date code off the block. (see pic below for location) We can tell that your engine is not original to your truck based on the numbers provided so far. Truck motors did not get partial VIN's till the mid seventies. You have a partial VIN on your motor so it can't be a 67-72 truck motor and therefore not original to your truck. Your suffix code identifies it as a truck motor and not a passenger car motor so the block must be later than 1975. (TDR the T indicates truck) Suffix codes do not tell whether the block is a 2 or 4 bolt. C8F181490 C = Chevrolet 8 = 1978 F = Flint assembly plant 181490 = Unique ID number of the truck the engine was originally installed in V0425TDR V = Flint engine assembly 04 = April 25 = 25th of April TDR = 71 350ci,255hp, Auto TDR = 72 350ci,175hp, Auto TDR = 80 350ci,170hp, Auto This is where we have a discrepancy. Your partial VIN is for a 1978 truck, but I can't find the TDR suffix code being used in 1978. It could be that the online websites and the reference materials I use have omitted the listing for some reason. Or could be a miss read on your part, or a miss stamp from the plant. You have a 350ci from the late seventies, but to find the year you will need to check the casting date code on the block. Should be a letter followed by 2 to 4 numbers. (ex D28, D208 or D2078) Please recheck the suffix code(TDR) and the second digit of your partial VIN(the 8). Although most likely you have them correct and the TDR suffix code for 1978 is just missing from the publications. Definitely check the block casting date code. Then we can determine what year your 350ci is. See pic below for location. Casting numbers always trump Stamped numbers.
CHEVY/GMC VIN DECODERS Last edited by bruceman1968; 01-24-2018 at 04:36 PM. |
