opinions on updated chassis wiring?
what's everyone upgrading to when it comes to chassis wiring? i've been looking at the american autowire. any opionions on this kit or any others i should look at.
![]() Join Date: Jan 2015
Re: opinions on updated chassis wiring?
I've done 4 different cars with Rebel harnesses and plan on doing this truck with one too.
It's Better With Nitro
American Autowire is good. I use Ron Francis on all of my hot rod projects, including my C10 that I'm currently wiring. It comes pretty custom and pre-wired according to the application and user specified options. Each kit comes with an individual serial number, so customer service is specific to the kit.
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
American autowire is who I use. I have used some that were much cheaper but imo, cheaper isn’t always better.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
I used AA, Classic Upgrade kit. Very pleased, made it easy for added AC, power windows, fan, HEI, third brake, rear gas, custom gauges, and more...
292 + TKO500 |
American autowire come with new plugs. even comes with dew dimmer switch, headlight switch and a few other pcs which saves money elsewhere. I looked around a bunch last night and pretty sure that's what i'm going with. i'm going to call and see if theres enough room in their relay/fuse panel to make my standalone ls harness go straight to it
I used the AAW kit. It comes with damn near everything you need but you will need to buy or rent the crimping pliers. I got a pair off of Amazon for $40 that worked great.
![]() ![]() ![]() ![]() These crimpers allow you to make the factory style crimps ![]() One more thing here is the firewall diagram that shows where all the wires come through factory. Made by Member Racecougar. ![]() Bret
64' Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=586955 |
bj383ss
is there extra spots for relays/fuses in that kit? I need some extra spots for my engine harness wiring. I emailed AAW but no response yet. Either way I'm going that route for sure looks like the best kit out |
I just took this shot. There are extra places to plug in for ignition and battery sourced power. I don't know how many fuses you need. You could use the CB spot for something and the power seat plug if you not using that I suppose. There is also the fused spot with the number above it I think that is for an auxiliary harness or fuse block they sell can't remember.
![]() Bret
yeah looks like there are enough there thank you for that.
