Old 12-27-2017, 11:10 AM   #1
barry1982
2005 gmc 1500 z-71
Hi Guys, I just picked up an 05 GMC. Having starter trouble, one of the bolts that holds starter to engine block was extremely hard to remove. Discovered the threads on bolt are "galled". Want to clean up the bolt, and run a tap into block before installing new starter. Needed a 13mm socket to remove bolt, so thinking bolt is metric. Does anyone know the correct metric size and thread pitch? Need this info so I can get the correct tap/die. Thanks.
barry1982 is offline   Reply With Quote
Old 12-27-2017, 08:49 PM   #2
greasemonkey
greasemonkey's Avatar
Re: 2005 gmc 1500 z-71
Should be an m10x1.5.
1942 Master Deluxe
1969 C/10
1985 Blazer CUCV
1987 Jimmy
2004 Tahoe
2005 Silverado 1500
2005 Silverado 3500
greasemonkey is offline   Reply With Quote
Old 12-27-2017, 10:18 PM   #3
95 S_Trucker
95 S_Trucker's Avatar
A thread chaser would be better than a tap.
95 S_Trucker is offline   Reply With Quote
Old 12-29-2017, 12:18 AM   #4
barry1982
Thanks Guys.... M10 x 1.5 is the correct size. I chased the bolt with a die, and picked up a tap to run into the block.
