Old 12-27-2017, 11:43 AM   #1
_mg
Active Member
_mg's Avatar
Cab changed?
Truck originally from Idaho. From the pics you can see the color discrepancy. The owner's manual indicates green. Looks like a stamp in the VIN tag; was this required if the cab was changed?
_mg is offline   Reply With Quote
Old 12-27-2017, 12:37 PM   #2
oem4me
Re: Cab changed?
trim tag 544 indicates red with white. Truck has been repainted. Writing on manual cover is not exactly reliable "documentation", especially considering it could have been written at any point in time. No telling what the weak stamp on the VIN tag is for. Maybe ID as part of a fleet?
Old 12-27-2017, 02:01 PM   #3
Rickysnickers
Re: Cab changed?
If the cab has been changed, then you need the title that goes with the cab. The frame will most likely have a stamping # on it, but generally those are not used for titling purposes.
Old 12-27-2017, 03:10 PM   #4
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Cab changed?
How would someone move that type of VIN plate to another cab?
Old 12-27-2017, 03:20 PM   #5
hop sing
hop sing's Avatar
Re: Cab changed?
Followig
Save a tree support your local drag strip !!!
hop sing is offline   Reply With Quote
Old 12-27-2017, 03:58 PM   #6
60-66
60-66's Avatar
Re: Cab changed?
Glue , it almost looks like you can see something around it
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
Old 12-27-2017, 04:02 PM   #7
60-66
60-66's Avatar
Re: Cab changed?
If it were me , assuming this is a nice green body and the VIN matches the frame and 4x4 K series, I would just buy a new tag for the kick panel with the correct color code.
Old 12-27-2017, 04:41 PM   #8
_mg
Active Member
_mg's Avatar
Re: Cab changed?
Frame matches cab VIN. Thanks guys.
Old 12-28-2017, 04:38 PM   #9
_mg
Active Member
_mg's Avatar
Re: Cab changed?
I was able to track down the original owner's son and he says the truck was always green and the cab was never replaced. The mystery continues...
Old 12-29-2017, 01:22 PM   #10
yeah_yeah_na
Re: Cab changed?
following
yeah_yeah_na is offline   Reply With Quote
Old 12-30-2017, 06:12 PM   #11
VictoriaHardware
VictoriaHardware's Avatar
Re: Cab changed?
Based on the above evidence I would attribute this to being a vehicle assembly plant error. There is probably another red/white (544) truck out there with a green (503) trim tag paint code on it. The Trim or Wheelbase could have just as well been wrong, but in this case seem to match. The tag was installed after the cab was painted and was apparently not double-checked.
VictoriaHardware is offline   Reply With Quote
Old 01-08-2018, 04:04 PM   #12
1963c-10
1963c-10's Avatar
Re: Cab changed?
Appears to be grey primer under top right corner of VIN tag in post 1. Chevy used red oxide and black primer if I remember correct. Can't tell if the VIN has been removed and reinstalled as some plaints used spot welds as opposed to rosette rivets.
Have you sanded down an area to metal to see what the original base color was?
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
