12-28-2017, 03:03 AM | #1 |
Help please can I put a 2005 Silverado in my C10
Hey guys I know pretty much anything could be done but what will be involved and will it fit I'm doing an LS swap in the truck probably within the next few weeks and came across a 2005 front crossmember what complete front end wanting to keep the 6 lug pattern anyways and change over to disc brakes will this work
12-28-2017, 08:32 AM | #2 |
Re: Help please can I put a 2005 Silverado in my C10
I think if you measure the Track you will find it is WAY to wide for your C10!
12-28-2017, 09:17 AM | #3 |
1965 Chevy C10, 2005 4.8L/4l60
Too much work imo, 05 will be wider track and wider frame.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
12-29-2017, 12:39 AM | #4 |
60-66 Nut
That front suspension crossmember is welded to the frame. And as already said, the track width is quite a bit wider than the '63-'70 trucks. With that said, if you have all kinds of time to spend on it, plus the excellent fabrication skills necessary, go for it.
12-29-2017, 03:09 PM | #5 |
You know, that has been a dream of mine for years and years. After I win the Texas Lottery, I'm going to do that with a brand new Duramax.
Greg Smith a.k.a. "The Highlander" 1966 C20 Custom Camper, 2017 Chevy Silverado 1500 Highlander's Project Pics Highlander's web site: www.6066ChevyTrucks.com |
