Old 12-28-2017, 09:59 AM   #1
CG
BlahBlahBlah
Four speed shift knobs?
Does anyone make or can I get from another model a black four speed style knob without any of the markings on it. Black knob exactly like ours with the little ribs ... no numbers on the ball.
Old 12-28-2017, 10:06 AM   #2
Re: Four speed shift knobs?
There were transfer case knobs with no pattern on the '70 4wds with the shifter bent toward the driver. I saw the title and my mind went directly to my special little 4spd knob I might use on my '67 project with M22. It has the car 4spd pattern I need and is the same as the knobs you are talking about. It's from a Corvair Rampside with 4spd. Those were Muncies. I might make a shifter for the M22 by modifying a truck 4spdor transfer case shifter so it looks like it "could" be factory. Just one option at this point.
Old 12-28-2017, 10:35 AM   #3
BLT gmc
The knob off a T-221 is close to what you are looking for. ribbed edge no numbers, ? is are the threads the same, I am not 100% sure. Happy New Year, Bruce
BLT gmc is offline   Reply With Quote
Old 12-28-2017, 10:42 AM   #4
CG
BlahBlahBlah
I have a Lokar shifter for a turbo 400. And I thought a stock style knob might be kind of cool. I have a customer that laser engraves and he told me he could probably laser engrave the 400 shift pattern on a blank knob. That's why I would want an exact style knob but blank pattern.
Old 12-28-2017, 12:17 PM   #5
Andy4639
Old member
Andy4639's Avatar
Talking Re: Four speed shift knobs?
Something like this CG?
http://oliverparts.com/Gear_Shift_Kn..._66_77_88/p107
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 12-28-2017, 12:28 PM   #6
CG
BlahBlahBlah
Boy those are inexpensive. Worth getting one just to see how it works out. Thanks for the link.
Old 12-28-2017, 12:32 PM   #7
Andy4639
Old member
Andy4639's Avatar
It would be worth a try!
Old 12-28-2017, 12:33 PM   #8
I agree. I can't see paying any more than $7.38!
Old 12-28-2017, 01:11 PM   #9
jeffahart
jeffahart's Avatar
Here is the one I used. Five bucks. I got mine local at a truck stop for a couple bucks.
I used it for my transfer and had it engraved at things remembered for the 205 pattern.
https://www.tractorsupply.com/tsc/pr...t-knob-bb7213a
j
White K20
jeffahart is offline   Reply With Quote
Old 12-28-2017, 03:39 PM   #10
CG
BlahBlahBlah
Haha! Since you don't want to spend the extra 12 cents Ill buy two and send you one (cheapskate lol). Hmm I may still have your address somewhere.
Watch the mail Tim
Edit: The tractor supply one is even cheaper. I have to take off for awhile and I need to drive right past the tractor supply store.
Old 12-28-2017, 07:37 PM   #11
I appreciate the offer, but I'll happily pay 5 smackers for a knob at TSC (if I needed one).
Jeffahart, that came out real nice.
Old 12-28-2017, 07:58 PM   #12
jeffahart
jeffahart's Avatar
Thanks, I need to take a better pic. Once I figured out how to fill in the engraving with white paint it looks real nice. It's one of those things that's in my face every time I climb into the cab, so I've been enjoying it.
But... It cost me twenty bucks for the engraving!... ouch!!!!!
White K20
Old 12-28-2017, 11:05 PM   #13
midniteblues
midniteblues's Avatar
I've tightened some threaded rod into a regular white 4spd knob, chucked it into a drill and used sand paper to erase the pattern and polished it back out with finer grits and finally polish.
The white ball looked new clean, nick free and sweet.
I don't see why one couldn't do this with a granny 4 spd knob without hitting the knurled part
I used number stamps, some gun stock checkering tools , a fine point sharpie and tape for guide lines stamped and sketched it in.The number stamps only provided a guide for the font for engraving the numbers..
then touched it up with a dremeled and painted in a new 5 spd pattern.
Too bad I munched that weak little t50 the first time I abused it....lesson learned.
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline   Reply With Quote
