12-28-2017, 11:13 AM | #1 |
292 motor mounts used in swap!
hello folks I am doing a bit of research on building motor mounts to drop a 292 in place of my 230,, love to see what you have done !
12-28-2017, 11:56 AM | #2 |
It's Better With Nitro
Re: 292 motor mounts used in swap!
There are a few people making the conversion mounts. Generally, you'll need to go with an electric fuel pump since the adapter plate covers the mechanical fuel pump location.
https://www.12bolt.com/store/p40/Ste...t_Adaptor.html
12-28-2017, 12:03 PM | #3 |
Thanks vin63 I am trying to retain the mech pump,, But Tom Lowe has some cool stuff !
12-28-2017, 01:18 PM | #4 |
Don't know the right or wrong of it but I used a driver side motor mount and three 1" spacers. The spacers were made out of 3/8" galvanized pipe placed between the block and the motor mount. Poor mans fix and everything is straight and level. The benefit is being able to use the mechanical fuel pump.
12-28-2017, 02:19 PM | #5 | |
12-28-2017, 04:36 PM | #6 |
I stand corrected. The bottom two bolts are the ones with the 1" spacer. I do have photos takes today. All I need to do is find a way to add photos.
12-28-2017, 04:38 PM | #7 |
just get the passenger side frame perch for a 292 instead of MM'ing it.
ron |
12-28-2017, 10:00 PM | #8 |
12-28-2017, 10:05 PM | #9 |
mm stands for Mickey Mouse
ron |
12-29-2017, 12:54 AM | #10 |
60-66 Nut
I agree.....just use the correct engine mount bracket. I probable have a couple laying around.
12-29-2017, 11:32 AM | #11 |
When I was doing my search it seamed like nobody had them or they wanted an are and a leg for them. Since I am not doing a correct restoration I made do. As far as Mickey is concerned what I did was structurally sound.
03-01-2018, 01:30 PM | #12 |
03-01-2018, 02:46 PM | #13 |
If The Captain can't help you, I have one I will sell for $40.00 plus whatever for shipping. I assume this is for a 2wd? Mine came out of a 66.
Tom
65 short stepside K10 292-SM420-T221 8 lug closed D44 front NoSpin HO72 4.10 rear |
03-02-2018, 12:12 AM | #14 |
60-66 Nut
I will have to look and see if I do still have any. Do you need just the passenger side?
