12-28-2017, 04:17 PM | #1 |
Brake Pedal for Auto vs 3OTT
Was wondering if I take my truck from a 3OTT to auto will I need to change out the brake pedal or can I just eliminate my clutch pedal and call it done? Thanks
12-28-2017, 05:25 PM | #2 | |
Old member
Re: Brake Pedal for Auto vs 3OTT
Pedals are the same no matter which one it is. I went with a billet pedal add on to make it look better.
12-28-2017, 05:57 PM | #3 |
The Older Generation
As Andy said, pedals and bracket are pretty much the same. Just remove the clutch pedal and shaft. There are a few threads on here that show how to do it.... LockDoc
12-29-2017, 09:57 AM | #4 |
Thank you for your responses. Dave
12-30-2017, 11:22 AM | #5 |
You certainly *Can* just remove the clutch and call it good, but there *are* two different kinds of brake pedals. One--used with some auto trans applications--is wider than the other, which was used with manual applications.
Also, be aware that there are two pedal hanging mounts, one of which is *MUCH* more difficult to pull the clutch pedal from. I lost part of a finger doing so on my '69: be careful of the heavy spring. If it over-centers, it will pull the pedal arm across the bracket like a shear.
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt. |
12-30-2017, 08:27 PM | #6 | |
Old member
Please post a picture of the different brake pedals for a 67-72 C 10. I would like to see it so I can try and find one. I have never seen one from the factory that wasn't the same as the 3 speed.
12-30-2017, 08:39 PM | #7 |
i see chevy spaghetti !
Stan 67 swb BLU MULE posted via flip-fone |
