Best Under Bed Fuel Tank Conversion.
I know what you're probably thinking: I should have used the search function. I did but didn't see anything about quality, ease of kit install etc. About the only thing I did see was don't go with poly, use a steel tank.
We are doing this on a short step side and going with an in tank pump for fuel injection. There are a lot of options as far as tanks, don't know about working with in tank pumps so much. I just wondered what most had good luck with as far as kit quality, etc. Thanks. Last edited by Justin Jones; 12-28-2017 at 07:11 PM. |
#2 | |
Re: Best Under Bed Fuel Tank Conversion.
1970 GMC 2500 700R Trans RideTech 4 link rear suspension - Air Bagged on all four corners 350 SBC 300hp Weiand Supercharger FiTech EFI |
I think we'll do an external replaceable filter just like a regular car/truck. But honestly I didn't think about access to the fuel pump if something happens to it. I guess we'll drop the tank to change it.
I used a 49-52 chevy sedan from tanks inc. It will fit inside rear frame and put filler cap on rear of fender.. smoothed gas cap. 16 gals setup for fuel injection. I like it and you cannot see it from behind.
You still need to be able to replace the fuel sock filter on the inlet side of the in tank fuel pump. These EFI fuel pumps need an inlet filter.
#6 | |
![]() Join Date: Feb 2004
Whats wrong with poly. I run a 2002 camaro tank. Required trimming the bottom of the frame, and relocating rear most bracked a little bit. The up side is you can use a stock ls pump or run the racetronix upgrade like I do😁 it supports 650 HP.
Edit: you will need to drill A hole through the frame for the filler. Mine is in my bed.
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride! ........................ ___ .........________//__{\_____ ,,,,,,,/__(⊙)___//___/__(O)_/ @disciple2.rc 💪instagram💪 LED TAILS |
I run a Boyd Aluminun tank with the in-tank pump. It was well worth the money spent.
I’m considering using a 25 gallon tank from a 1989 blazer as described in an earlier post. I’ll have to move the cross member back and I’d like to position the tank so I can possibly fill it from behind the license plate. The tank is baffled in case you do a ls swap in the future.
Posted via Mobile Device |
![]() Join Date: Mar 2012
there as a post on here about a guy who used a 69 Camaro tank for his step side with the flip down license plate, that is the route I am going to go with
search 69 Camaro tank on the forum it should pop up
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks ![]() |
![]() Join Date: Jan 2011
I have a 69 Camaro tank under mine but it's a fleetside. ( Dont think it would matter really?) We used a flip down tag bracket off a 70s Impala. I'll post a picture if youre interested. ( there may be some pics on my build I cant remember ) We had to make some brackets and supports to make it work but it tucks under the truck nicely and of course you wont see a filler door or modifications inside the bed.
Chad 1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway* 1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy 1986 Silverado Short Fleet - Scarlet *Sold* 1985 Silverado Short Fleet *Sold* 2022 Jeep Gladiator Mojave 2001 Jeep Cherokee XJ 4x4 - Lifted, Built 1992 Jeep Cherokee XJ 4x4 - Lifted 2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride) |
by the way I bought the flip down plate holder from amazon, summit also sells them as well
#13 |
I would go with the camaro tank also if I wasn’t considering a ls swap eventually. The blazer tank is baffled and the camaro tank is not as far as I know.
#14 | |
Here's the link
1971 C10 - LQ4/4L80E swap in progress 1988 K3500 - 8.1 swap planned |
#15 |
Thanks, that’s good to know. Although I’ll still probably go with this one since it’s bigger and cheaper.
https://www.amazon.com/Spectra-Premi...=spectra+GM15C Posted via Mobile Device |
#16 | |
I might have to reconsider the Camaro tank.
#17 |
That’s my plan so I’m hoping it’ll work.
#18 |
I have quite a few other things on the list before I have to make a final decision on the tank, so if you don't mind letting me know how that works out that'd be awesome!
#19 |
http://67-72chevytrucks.com/vboard/s...&postcount=762
Here's how we did it. Starts around post 760 or so.
#20 |
Before and After
I guess one question needs to be asked.
Is this truck stock height or higher? Because if you are lowering it, a camaro tank will not work.
Not Grandpa's C-20 anymore... 383 Stroker 425HP, 485Ft/Lbs Lowered 3.5" Front / 5" Rear 66,000 miles. Alberta, CANADA |
#21 |
No intentions of 'disagreeing' here - but just to show you guys how it tucks into the frame and bed, clearance, etc. My truck is about 7" drop. The rear differential and track bar / lower shock bar hangs lower than the tank.
I had an aftermarket tank in this truck at first and the Camaro tank is a lot better. My old tank was the poly tank with the outlets and connections at the back.
#22 |
That is about how my 2002 camaro tank sets too
#23 |
Well this kind of got busy over the weekend. I'll try to respond to everyone.
Rufas - Our fuel pump module will have a sock or pre-filter on it. Just like the pump, the tank will have to be dropped to change it. Nice fuel door mod. We are looking at going through the fender lens being a step side. Dusty - Never knew that tank would work. I'll look into that. Being from Tanks Inc. we could get it set up for their fuel injection. Rob - Just a few threads said don't get poly. To me, it doesn't matter. Just wanted to go with a good one. Thanks for the pic. Jesse - Thanks for the info. mi396 - I looked into the '87 Blazer because I'd like to go with about 25 gal. But it has the filler neck coming out of the top and I don't think that will work with the bed. I'm not sure. BigMac and cc69rat - Thanks for the idea of the Camaro tank. We haven't really ruled that out yet. Not too keen on the rear fill though. Thanks for pics too rat. Sabbath - Thanks for the link on the tank. We are for sure using fuel injection but not sure what pump set up yet. WB72 - We are looking at lowering it but not sure how much yet. At least 2.5/4 drop. |
#24 |
I installed a poly tank from a 9C1 Caprice. I use a small external electric pump but the factory setup was for the SPFI LT1 and I think delivered 50+ PSI Used the Caprice mounting straps and fabbed front anchor mounts. Had to remove spared tire cross piece. It is visible from the side(s) and rear but not much.
#25 |
14.1 @ 96MPH
How is the license plate filler to live with? I want a rear tank, but I don't want to do any bodywork that will result in either redoing bedliner or paint because I don't think either can be blended realistically.
Project1970 - LS1 Swap Complete! ![]() |
