Don't blame the messenger
Measurement request
Can someone please help me out with the measurement from the back wall of the cab to the first bed mount?
On the Level Just a guy with a hammer and a grinder. OH!, and an HOA- enough said...: http://67-72chevytrucks.com/vboard/s...d.php?t=372525 "Some drink from the fountain of knowledge while others just gargle." |
![]() Join Date: Mar 2012
Re: Measurement request
when I get home I will check it out , my bed is off
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks ![]() |
![]() Join Date: Dec 2013
I have a '71 with the bed removed, measurement is 2 3/4. I can send a pic if needed. Hope this helps.
1972 C10 Custom Deluxe LWB, 402/400, PS, PB, A/C, Highlander, Hugger / White 1971 C10 Cheyenne LWB (SWB), 350/350, PS, PB, A/C, Dark Olive / White. |
Yes, that helps! Thank you very much. I’m sitting at 3 1/2”, maybe this explains why NOTHING is lining up.
That bracket steel is on an angle.
Best to measument form cab to center of bolt hole for more accurate placement.
My build page http://67-72chevytrucks.com/vboard/s...d.php?t=764662 My cabinet building site http://www.cbcabinets.com |
Pic! Just over 4 1/2 "
Great! Thank you all!
