12-29-2017, 05:30 AM | #1 |
Hatch latches
Started a little side project... Made cad models of the latches. Getting the geometry right so the teeth mesh correctly was a bit of a pain. Planning to fabricate a couple sets in stainless.
12-29-2017, 04:05 PM | #2 |
Re: Hatch latches
Nice. Always good to have options.
Kirk 72 Blazer CST 4wd highlander 66 Nova |
12-29-2017, 04:42 PM | #3 |
Re: Hatch latches
You got skills!
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
12-31-2017, 12:15 AM | #4 |
Re: Hatch latches
Looks good. Great idea for the durability and aesthetics!
Any plan to make more sets? I would be interested in a set if you do. |
12-31-2017, 05:07 AM | #5 | |
Re: Hatch latches
Anyone have a clean set of latches and can check something for me? Need to know if the area pointed at below should be curved like shown. Both of the ones I have look pretty beat up in that area, can't tell if that was the original shape or it has worn down. |
12-31-2017, 01:32 PM | #6 |
Carpe manana
Re: Hatch latches
Here's a pic from a NOS example I have. That section appears flat and parallels the opposite side. I have seven used examples here that are loose - the concavity depicted in above pic is from wear and not present when first installed. Hope it helps. Good luck with the project.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland Last edited by DeadheadNM; 12-31-2017 at 01:39 PM. |
12-31-2017, 01:35 PM | #7 |
Re: Hatch latches
Awesome... Had a feeling that radius shouldn't be there. Thanks.
