65 c10 small block and 305v6 radiator
Hello,
Trying to match up a 91 small block and a 305 v6 radiator. Intake manifold nipple points towards drivers side, radiator inlet is on the passenger side. Lower hose looks like a regular hose, just need to shorten and get right diameters. Top of radiator is 1 3/4 hose size top of engine is 1 3/8". Bottom of radiator is 1 7/8" and water pump outlet is 1 5/8". Any suggestions for how to do this without 500 trips to the parts store? |
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: 65 c10 small block and 305v6 radiator
For starters, take the radiator to a radiator shop and have the inlet moved to the drivers side. In doing so, they may be able to install one that is closer to 1-3/8" in diameter.
thanks captain. didnt know that was an option.
