12-29-2017, 11:17 AM | #1 |
72 Steering Wheel Changed Wrong
Just bought a 72 with a Z28 steering wheel that is installed wrong about 45 degrees to the right of center,and the turn signals don't cancel at all and the horn does not work. Any ideas as to how to resolve??
Newby here... |
12-29-2017, 11:34 AM | #2 | |
Old member
Re: 72 Steering Wheel Changed Wrong
To get the steering wheel straight just pull it off and put it on straight.
12-29-2017, 12:33 PM | #3 |
Make sure you use a steering wheel puller or you will likely damage the column. Cheap to buy or rent from many auto parts stores.
12-29-2017, 07:55 PM | #4 |
Thanks for the info I will post when I get a chance to check.
