12-29-2017, 11:22 AM | #1 |
Junior Member
67-72 van tilt column
Can anyone advise me if the stock steering wheel and horn on from a 66 p.u. will work on this column? I seem to get varying info on a search.
Thanks! |
12-29-2017, 11:50 PM | #2 |
Re: 67-72 van tilt column
Not sure how much of a difference there is but I was able to use my 65 deluxe steering wheel on a 72 pickup tilt column.
12-30-2017, 12:13 AM | #3 |
Junior Member
Did the stock horn mechanism work or did you have to hook up a remote button of some sort?
12-31-2017, 10:12 AM | #4 |
I'm using the stock horn setup. I am having intermittent horn issues but I think it's inside my steering wheel as it only happens once in awhile. I haven't had my wheel off since I had the column installed in 1999.
12-31-2017, 11:11 AM | #5 |
Junior Member
Thanks!
01-01-2018, 06:42 PM | #6 |
No problem. Good luck with it
