Old 12-30-2017, 01:43 AM   #1
Flip64
Gears
I have a 1964 c10 with a straight 6 An 4 speed on floor. I'm running 22 on rear An 20 on front. I run at 60mph turning 4K. Yea a little high. Looking to find a more highway gear. But don't no what to go with. Is there any other rear ends out there that will match up to mine. I'm not for sure what gears r in it now.
Flip64 is offline   Reply With Quote
Old 12-30-2017, 02:07 AM   #2
mongocanfly
Post Whore
mongocanfly's Avatar
Re: Gears
welcome. ..holy cow!!! ....4000 rpm?...rim size has no effect on rpms....you need to know 4th grear in trans ratio, rear axle ratio, and tire diameter....you can plug numbers into calculator like this to find what you need for a axle ratio to get your rpms down....
http://www.csgnetwork.com/multirpmcalc.html
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 12-30-2017, 02:11 AM   #3
mongocanfly
Post Whore
Re: Gears
you'd bout have to have a 5.13 rear ratio and 26in tall tire to turn 4k with a 1:1 final in the trans at 60mph
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 12-30-2017, 03:33 AM   #4
Flip64
Old 12-30-2017, 12:55 PM   #5
LockDoc
The Older Generation
LockDoc's Avatar
Re: Gears
I will move this to the 60-66 truck forum.
LockDoc
Leon
Old 12-30-2017, 05:18 PM   #6
LVPhotos
LVPhotos's Avatar
Re: Gears
Here we go again.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 12-31-2017, 12:14 AM   #7
Captainfab
60-66 Nut
Re: Gears
It sounds like your tach is not set to the 6cyl setting.
Old 12-31-2017, 01:04 PM   #8
rvrfoot
Re: Gears
Frist thing frist running at 4g will tear your motor apart.
rvrfoot is offline   Reply With Quote
Old 01-01-2018, 04:22 PM   #9
oldusafmsgt
oldusafmsgt's Avatar
Re: Gears
Gear is the least of your problems. I'd start engine shopping, if that six is turning 4K, you're going to need one soon.
1960 Chevy Apache10 Short Fleetside
1961 Chevy Apache10 Short Fleetside
1961 Chevy Apache20 Fleetside
1963 Chevy C10 Short Fleetside
1965 Chevy C10 Short Stepside
1965 Chevy C10 Long Fleetside
1966 GMC 1000 Long Fleetside
1966 Chevy C10 Short Fleetside
oldusafmsgt is offline   Reply With Quote
