Adding vent to sending unit or charcoal canister
Anyone add a vent to there in cab gas tank sending unit? Installing Holley Sniper and my tank has no vents or return lines....
OR...added a charcoal canister if I use sump unit, seems to be best in my mind. If I buy new tank, it will be rear top fill unit, cha-ching..trying to keep from throwing $$$ at it....... |
#2 | |
Old member
![]() Quote:
Most cab tanks have a vent line. It goes up the back side of the cab on the passenger side and back down to the tank. ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#3 | |
Who Changed This?
![]() Join Date: Jan 2013
Re: Adding vent to sending unit or charcoal canister
Someone who has installed this setup will be along eventually to tell you how they did it.
#4 | |
I have done this , I first tried it by buying a 72 sending unit to utilize the vent that is already there ,but the sending unit only lasted about 2 months before it went bad giving me bad fuel gauge readings and I bought the better one (brass Float) vs plasic float .
I ended up drilling , tapping and then soldering over a brass fitting in my original sending unit , No problems at all . in the picture you can see were I put the bulkhead fitting in for the return line, above to the left of the sending unit , the vent hose runs to the passenger door ,I pulled out the upper rubber grommet door stop and put the vent line through that exsisting hole, fit 1/4 hose perfectly and vents with no issues. |
Old member
My 71 C-10 had all of this in it factory. I took it out when I did the 305 TPI years ago. I put the tank in the bed and ran vent lines so no need for the canister.
The canister is only to keep the gas smell down when venting. Found this on the H.A.M.B site vent line should be 1/4" , and have atleast two large 3" loops in it the loops helps prevent the vapors from coming out as they are heavy and settle in the bottom of it . you can install a electric valve in the vapor line that opens when the ignition is keyed on ( did this for one car ) its a tank switching valve from a chevy 78 k 20 truck it has no vent option as its non emissions ( exempt for time ) also have done vapor canisters from late model vehicles as they are smaller and cheaper new . 4th gen impala works good . ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. Last edited by Andy4639; 12-31-2017 at 11:27 AM. |
#7 | |
#8 | |
