Time To Replace Rear End
Sorry for the long post in advance, but i need some advice please,
I have had this truck for 20 years, used to be my daily years ago. I just got transmission fixed and running after 4 years of sitting and blew out my 10 bolt rear end with impala posi unit, (Not a G80) I dont have much motor. a 355 SBC 440 rwhp with a 100 shot. Its mostly for burnouts and mustangs and trips to the beer store. I have a 14 bolt 6 lug sf rear end from a 93 3/4 ton 2wd truck with G80 and 3:73 gears, I plan on changing the G80 out, am i correct in thinking this? I spoke with Dutchman axles and they can make me 5 lug axles, would this then be similar to the factory SS rear ends with 5 lug? It looks like it from the research i have done but would like some verification. I can buy a factory 5 lug SS 14 bolt G80/3;73 rear local for $500, I dont think i would be saving anything here would I? My main concern is this thing is huge, axles are even huge. I know this would probably never break, Im just concerned that it is overkill for my application. Axles are $370 Posi Are About $550 and disc brakes with emergency brake kits is $535. This gets me close to $1500 by the time I get it all together with parts fluids and labor. Im only thinking the disc brakes will save weight over the heavy drum brake set up. I had a Nova that ran 7.33 in the 1/8 mile that had a good 12 bolt with posi and axles and never broke anything. It is Also cheaper to do rear disc brakes or use factory drum brakes on the 10/12 bolt. 14 Bolt, new posi, axles, use factory 3:73 gears? Replace the G80? 12 Bolt with new posi,new aftermarket axles and gear. I realize I would need to weld new leaf spring perches to use this rear end 10 Bolt with new posi,new aftermarket axles and gear I know I can switch to 6 Lug easy but I want to stay 5 Lug (I just Got New 5 lug Wheels) I want to Stay GM - NO Ford Parts on my Chevy So if your gonna spend $1000-$1500 what would you do? Thanks in advance for your opinions. |
| Bookmarks |
