12-31-2017, 02:51 PM | #1 |
windshield sealent ?
It seems that a lot of us have trouble getting windshields not to leak. I will be installing mine soon and don't want to do it twice, or more, because it leaks. After 50 years or so, the lip that is central to it all is rarely "perfect". So is there a sealent or some other "trick" that could aid in this? My 66 GTO uses a 5/16 "ribbon sealent" and a "window weld resealent" for the windshield, made by 3M. Would/could these be appropiate for our 67-72 trucks or are we stuck with trusting a new rubber mounting strip and a prayer? Or maybe just pay a glass shop to do it and make sure they guarantee it not to leak!!!!!
12-31-2017, 05:11 PM | #2 |
Re: windshield sealent ?
Maybe this might be of help ...
To seal or not to seal, that is the question? http://67-72chevytrucks.com/vboard/s...d.php?t=413711 Windshield Install Adhesive or no http://67-72chevytrucks.com/vboard/s...d.php?t=742655 Windshield gasket blues: Precision supplies Steele and possibly Soft Seal http://67-72chevytrucks.com/vboard/s...d.php?t=484773
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
01-01-2018, 12:16 AM | #3 |
Make sure that if you use a sealant it's a flow-grade butyl rubber. That's the correct sealant for rubber gaskets. Many manufacturers used urethane sealant around the early 80s as they transitioned to urethane-set windshields, but that was a stopgap measure intended to meet newer structural requirements and isn't necessary for our trucks, and will likely mean your new gasket will be destroyed the next time you replace your windshield.
Your GTO doesn't use a rubber gasket. The glass is glued to the pinchweld with the ribbon sealer, which is a heavier butyl rubber. It's a different type of installation.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
01-01-2018, 07:46 AM | #4 |
The Factory service manuals in the body section tells you to Use sealant along with the seal during install to prevent leaking so the answer is of course use sealant.
GMCPaul |
01-01-2018, 08:24 AM | #5 |
Thanks for the replies
01-01-2018, 01:48 PM | #6 |
It's been a while since I took a look at it, but I believe it specifies 6 or 8 inches at the top corners. Having been in the glass business for years, I found that they rarely leaked anywhere else unless it was a bad installation (bunching in the seal) or there was an issue with the windshield frame.
01-01-2018, 02:55 PM | #7 | |
1970 GMC 2500 700R Trans, RideTech 4 link rear suspension, air bagged on all four corners, factory upper/lower A-Arms, 2 inch drop spindles. 350 SBC 300hp Weiand Supercharger FiTech 30004 EFI |
01-01-2018, 03:03 PM | #8 |
Between the rubber and the body.
02-08-2018, 10:48 AM | #9 |
Has anyone had the glass and rubber seal leak? I'm asking because that's what it looks like in my 69 C10. When it rains I see water come up from the rubber seal and drip down on the dash, drips on both lower corners. It is a new seal and glass installed by the previous owner.
1969 CST/10 396 |
02-08-2018, 11:11 AM | #10 | |
The Older Generation
LockDoc
02-08-2018, 11:50 AM | #11 |
Thanks Doc, I wasn't sure if the sealant between the rubber and body would fix what I am seeing. I will try what you suggest and se where that gets me.
1969 CST/10 396 |
02-08-2018, 12:05 PM | #12 | |
If you see any rain before too long report back and let us know either way. Thanks, LockDoc
02-08-2018, 12:17 PM | #13 |
I had to use windshield sealant in the upper corners of mine only, but that was after a dry installation.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
02-08-2018, 08:01 PM | #14 |
I applied some windshield sealant this afternoon so when I get some rain I’ll see if it worked
Posted via Mobile Device |
02-16-2018, 09:53 PM | #15 |
Unfortunately my windshield still leaks. The dripping on the floor is less but the water coming in around the seal and glass at the bottom is still happening. I'm not sure what the next move is, I don't want to remove the glass and seal since they are new.
1969 CST/10 396 |
