Old 01-01-2018, 06:43 PM   #1
kenny4454
New Foam Issue
I just had my 69 c10 full foam bench seat redone with new foam from PUI. The seat looked great, but when installed my head was 1/2 inch from the roof and my aftermarket 13 inch grant steering wheel was in my knees (I'm 5'10).
I am wondering if anyone else has purchased the full foam from PUI and how they resolved the issue. The foam is very stiff and am not sure if it will 'break in' being the truck isn't driven daily. I am hoping to gain more room again and be able to put the original steering wheel on the truck. Thank you in advance and happy new year!
kenny4454 is offline   Reply With Quote
Old 01-01-2018, 07:29 PM   #2
Gromit
Re: New Foam Issue
Not from PUI but I fabbed my own foam and I had this issue too.. I'm 6'3" (about up to Lurch Adams's nose).
I did find my bench seat foam has softened a bit.. I sit maybe 3/8" lower so far and every eighth inch makes a difference.
Only thing I can think of is remove the seat from the truck, take off the back, remove the lower seat cover and use an orbital sander to take down the foam a little; but I don't recommend it.
There might be some better suggestions in the archives of this forum
Gromit is offline   Reply With Quote
Old 01-01-2018, 07:33 PM   #3
harpo231
harpo231's Avatar
Re: New Foam Issue
I think there were full foam and thin foam seats ,i may be wrong
Stan
67 swb BLU MULE
posted via flip-fone
harpo231 is offline   Reply With Quote
Old 01-01-2018, 07:51 PM   #4
Shinysideup
Shinysideup's Avatar
Re: New Foam Issue
Some insight
http://67-72chevytrucks.com/vboard/s...d.php?t=676733
._____________
..\ .___ . . . . _ . .\. . . . . . . . . . . ___
..| /_+_/ ___ |o| ...}. . . . . ______i__!\____
. [_____(O)_|_'|__}>-------[-_(O)__i'___i (O)-]
Originally Posted by 68 P.O.S. View Post
No thank you on that lifetime warranty. I don't want a turd for life.
Shinysideup is offline   Reply With Quote
Old 01-01-2018, 09:40 PM   #5
Steeveedee
Who Changed This?
Steeveedee's Avatar
Re: New Foam Issue
Interesting! Subbed. I need to do the seat in my truck. If my dad was alive, he'd make it done right.
~Steven
Simi Valley, CA
Old 01-03-2018, 01:11 AM   #6
Daaaanz67
Re: New Foam Issue
Subbed
Daaaanz67 is offline   Reply With Quote
Old 01-06-2018, 10:20 AM   #7
kenny4454
Re: New Foam Issue
Thank you all for the feedback. I did read some previous threads on the forum before starting this project. For me repairing the foam was not an option and I made certain that my bench seat is a 69 C10 full foam bench seat.
The full foam on my bench seat is from PUI and I am wondering if ACI foam is less dense? I know this is the more expensive route and not the one that I wanted to go down. However, I am trying to figure out if anyone that has installed ACI full foam bench seat into their C10 has had similar problems. Please let me know if anyone can confirm that ACI foam is less dense and my head will not be hitting the roof.
Old 01-06-2018, 10:45 AM   #8
Grumpy old man
Grumpy old man's Avatar
Re: New Foam Issue
Take it back to whoever installed it , They can easily reshape / cut down the foam to fit your BUTT !
Grumpy old man is offline   Reply With Quote
Old 01-08-2018, 10:42 AM   #9
68Stepbed
68Stepbed's Avatar
Re: New Foam Issue
Check out www.fullcustomfab.com for the lowered brackets. You'll thank me later!
https://squareup.com/store/full-cust...ead=item_embed
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 01-08-2018, 07:46 PM   #10
kenny4454
Re: New Foam Issue
Thanks everyone for the suggestions. Shaving the foam is an option as well as the lowering brackets. I saw some guys modifying their original brackets, but did not know there was someone selling them. Good to know!
Old 01-08-2018, 08:11 PM   #11
demian5
demian5's Avatar
Re: New Foam Issue
Always have the shop use their own foam, and tell them what you want.
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
