65 gas pedal picture
Can anyone post a pic of a stock 65 gas pedal and it's linkage. I have tried in vain to come up with a pic from any source. My 65 only came with the upper linkage to the gas pedal , that bolts to the inside of the firewall, and am trying to figure out how the darn thing actually works so I can find the right parts.
Re: 65 gas pedal picture
Early classic enterprises. They have all you need. The pedal is $12
At my worst I'm at my best |
Does it bolt to the floor with two ball looking bolts? How does the pedal affix to the arm mechanism?
Yes, just snaps on then rest on the arm/linkage.
Sweet. Thanks very much that clears up alot.
No worries, lokar sells a hanging pedal assembly for these trucks too if you’re interested.
here it is from the floor up, the rest of the pictures may help someone else sometime..
'65 C20 283 / 4sp ![]() ![]() ![]() ![]() ![]() ![]() ![]()
I started out with nothing - and I still have most of it |
Dude you totally rock. That is exactly what I needed. Pictures are so much easier to figure things out from. Has anyone tried putting a throttle cable at the end instead of an arm?
What type of bolts are used to bolt the pedal to the floor?
no worries, it's sitting out back doing nothin right now..
phillips screws ![]()
Sweet. just ordered the new pedal from early classic enterprises so I will be set. Thanks for everything.
