Old 01-03-2018, 12:48 PM   #1
ScottH
ScottH's Avatar
Exclamation Need help with Diff dilema
Recently picked up a 65 & wanted to check the gear ratio in the rear. So I jacked it up, marked driveshaft & wheel, & turned the wheel.
Was surprised to c the driveshaft started to turn, then stop, then turn a little more, then stop. So tried turning the driveshaft, same results with the tires.
As far as I know its an open rear as the tires turn in opposite directions.
Too damn cold to pull the cover off.
Can anyone shed some light on why this is doing what its doing? I drove the truck b4 buying it, was slow (which is why I want to change the gears), but didnt notice anything out of the ordinary.
Any info, suggestions, opinions would be greatly appreciated.
Scott
1963 C10 swb fleetside
1966 GMC G1000 Handi-bus (future project)
1955 Chevy 2 dr. wagon
ScottH is offline   Reply With Quote
Old 01-03-2018, 12:56 PM   #2
jchav62
1962 C-10
jchav62's Avatar
Re: Need help with Diff dilema
I believe you want to 'stop' one wheel from turning to get a true count of rotations. Jack only one tire up... then spin the shaft. Count the rotations of the shaft per one revolution of the tire. With both tire spinning in opposite directions, you won't get a true count.
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 01-03-2018, 02:01 PM   #3
ScottH
ScottH's Avatar
Thanks, that makes total sense, think my brain is running slow due to the cold weather.
