Old 01-03-2018, 01:00 PM   #1
l79m20
1966 delco starter numbers oem
can someone list the oem Delco starter numbers called out to fit a 1966 1/2 ton 250 /PG originally. Trying to keep my truck original TIA
l79m20 is offline   Reply With Quote
Old 01-03-2018, 01:32 PM   #2
60-66
60-66's Avatar
Re: 1966 delco starter numbers oem
You asked this question in another post . I answered you there. 1107260 I believe is the number you need for that combination. If you have a build sheet, it will be on there also
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
Old 01-04-2018, 11:02 AM   #3
l79m20
Thanks for the reply , I just went through open heart surgery and things are still foggy . Please forgive my forgetfullness. Kirby
