![]() Join Date: Dec 2014
Seven gauge upgrade
I have a 68 C10 with the basic speedo/gas/idiot light cluster and want to install a used full gauge instrument cluster that i bought.
Can I use my current wiring harness that plugs into my basic cluster or do I have to change or modify my wiring harness? I realize that I have to run an oil line to the engine for the oil pressure gauge. What do I have to do about the ammeter and water temp for their signals? I've ordered a new bezel,5000 RPM tach, lens with tach and vacuum and a printed circuit w/tach that I plan on using in my truck. I still need to find a vacuum gauge that is in my budget. I look forward to enjoying these upgrades to my C10. |
Re: Seven gauge upgrade
you need to change the wiring in the harness plug to the instrument cluster. Do NOT plug a gauge cluster into an unmodified idoit light harness (or vice versa) WITHOUT changing some of the connections around, you will damage something (maybe the fuel gauge).
See this as a start: http://67-72chevytrucks.com/vboard/s...d.php?t=645940
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
The link above along with tis one should get the job done.
http://67-72chevytrucks.com/vboard/s...d.php?t=588853
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
Thanks for all the information guys.
Tackling this conversion is going from scary to exciting with this new knowledge. Cheers!! Ron |
