Old 01-03-2018, 07:41 PM   #1
65chevysub
65chevysub's Avatar
TH350 to 700r4 conversion
Can someone point me in the right direction of the post or thread that tells what is needed to change from a TH350 to a 700r4 with overdrive? I cant seem to find anything.
I have a 65 Suburban 1/2 ton 2wd that will be getting a 350 this year. Currently have 3:73 rear gears but need new of those as well
Thank You
65chevysub is offline   Reply With Quote
Old 01-03-2018, 08:10 PM   #2
sixty4bigwindow
sixty4bigwindow's Avatar
Re: TH350 to 700r4 conversion
Not sure of the entire "needs list" for doing a swap like that. But under the tranny FAQ section. There is a post by 1bad62 here that has a lot of good transmission info. Hope it helps
http://67-72chevytrucks.com/vboard/s...d.php?t=390542
Been a crazy 2018. Moved twice, back HOME in Oregon. Now to put everything back together, including the truck...
My build thread for "Rocket" - http://67-72chevytrucks.com/vboard/s...d.php?t=753023
sixty4bigwindow is offline   Reply With Quote
Old 01-03-2018, 08:47 PM   #3
65chevysub
65chevysub's Avatar
Thank you
Old 01-03-2018, 09:25 PM   #4
sixty4bigwindow
Originally Posted by 65chevysub View Post
Thank you
No prob man! Love your burb!
Old 01-04-2018, 12:33 AM   #5
Captainfab
60-66 Nut
There are tons of posts in the Engine and Drivetrain section all about correctly setting up the TV cable and adjusting the line pressures. As for the actual install, it is basically just moving the trans crossmember back and having the driveshaft shortened. You can either use your existing shifter or change that to your liking.
Old 01-04-2018, 09:52 AM   #6
65chevysub
65chevysub's Avatar
Thanks. Lot of memories with the old girl from when my dad bought it in 1976 up until now.
Old 01-04-2018, 09:54 AM   #7
65chevysub
65chevysub's Avatar
Thanks Captain. Im going to start looking ibto this swap. What gesrs would you recommend for daily driving? And could I keep them after the swap?
Old 01-04-2018, 11:00 AM   #8
PGSigns
PGSigns's Avatar
I have a 350 and a 700R4 in my 66 with a 373 gear. Not a bad combo. I drive it every day. If I did more long interstate runs I would put a 342 in it and still might. Running 65 it turns right about 2000 rpm. I have a 342 to go in my burb and I think it will be a good combo. That one is getting a 5.3 4L60 combo.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 01-04-2018, 12:26 PM   #9
chevy_mike
Never Ending Projects
chevy_mike's Avatar
3:73 and a 28"-29" tall tire is perfect. You don't want to lug the engine and ideal RPM's are in the 2100-2300 range at whatever your normal max cruise speed is. If you have EFI, you can lower the RPM range a couple hundred but on a carb, you might find worse mileage.
My old '68 C10 had 4:10's, 28" tall tires and cruising at 70 MPH, I could get 21 MPG. Downside was due to the deep first gear and the 4:10's, I would smoke the tires if I got on it too hard.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 01-04-2018, 03:34 PM   #10
sixty4bigwindow
Like smoking the tires when you dump the gas pedal is EVER a bad thing??
Old 01-04-2018, 04:19 PM   #11
65chevysub
65chevysub's Avatar
Jimmy
Thanks Jimmy. Right now with a TH350 and a 283 Im turning 4000-4500 rpm at 70-75mph. Waaay to high. I will see how the 3:73's do after I get everything in and set. Id like to take it on long runs but cant ubtil I get the rpm and mileage issues fixed
Old 01-04-2018, 07:50 PM   #12
PGSigns
PGSigns's Avatar
First thing you need is a good tach. You would have to have a 4.56 gear with a 28" to turn 4000 at 70 mph. With a 4.11 you would be at 3500 and about 3200 with a 3.73.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 01-05-2018, 12:31 AM   #13
Captainfab
60-66 Nut
This \/ \/ \/
Jimmy
Since a 283 is low on torque, I would go with 3.73 gears and the 700R4. You could go right to 3.42's if you plan on a lot of highway driving and do not plan on towing anything.
Old 01-05-2018, 01:12 AM   #14
rvrfoot
I have a 66 c10 with a 350 motor and a 350 trans. I think i have 373 gears. When i am going 60 my motor screaming. I was told i need 308 gears.
rvrfoot is offline   Reply With Quote
Old 01-05-2018, 06:06 AM   #15
The Rocknrod
Moderator
The Rocknrod's Avatar
This calculator is great to figure what gearing you need with your tire size.
http://www.csgnetwork.com/multirpmcalc.html
Old 01-05-2018, 08:33 PM   #16
65chevysub
65chevysub's Avatar
When you say 28"-29" tall tires, are you measuring from the ground to the top of the tire? Currently Im running 235/75r15's but will be dropping to I think a 225/75r15 which is the equivelant of the original 7.15-15
Old 01-05-2018, 09:55 PM   #17
rvrfoot
when you say 28"-29" tall tires, are you measuring from the ground to the top of the tire? Currently im running 235/75r15's but will be dropping to i think a 225/75r15 which is the equivelant of the original 7.15-15
yes.
Old 01-05-2018, 10:41 PM   #18
65chevysub
65chevysub's Avatar
Originally Posted by rvrfoot View Post
yes.
