Universal Wiper Kit from EZ Wiring
I have no parts for the windshield wipers on my 53 Chevy 3100. I am looking at the Universal Wiper Kit from EZ Wiring https://www.ebay.com/itm/Universal-P...dYMz-P&vxp=mtr
Does anyone have this kit installed? Can it be installed such that the wipers operate the same way as the original wipers (I am assuming this requires that one of the wiper wheel boxes be installed on the opposite of the drive cable)? Thanks. Wade |
Re: Universal Wiper Kit from EZ Wiring
I guess no one has used this kit. Any suggestions for windshield wipers if I am starting with nothing (no wiper transmission or wiper motor).
Thanks. Wade
53 Chevy 3100, SBC 355, 700R4, S10 frame, Ford 8.8 rear with 4.11 gears, front disc & rear drum brakes |
As long as the transmissions can be adapted to fit in the stock locations, I don't see why it wouldn't work. I'm curious how the sweep is adjusted, the photos don't show much detail. Like any other "universal" part, some fabrication will be required.
I have used this on a couple trucks and it worked good.
https://www.classicparts.com/1947-53...tinfo/67-064C/ |
#5 | |
53 Chevy 3100, SBC 355, 700R4, S10 frame, Ford 8.8 rear with 4.11 gears, front disc & rear drum brakes Last edited by Driver_WT; 01-07-2018 at 04:35 PM. |
Check classifieds, should be able to find good used wiper parts at good price.
![]() Join Date: May 2007
I have used the newport engineering kit and it is absolutely wonderful.
the one thing I will mention is that the newport instructions say to bend the arms (under the dash) to make the system work smoothly, but on the one I used I shortened the passenger rod 1 inch and everything worked perfectly. these are high torque assemblies so a bend will eat up valuable torque, I have read complaints about how the passenger arm will work slower on these kits, and that was my experience (and losing the clips when the passenger arm would pop off) untill I just pulled the arm and shortened it by cutting and welding.
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
