01-04-2018, 05:33 PM | #1 |
Junior Member
WTB 67-68 4x4 rear leaf spring plate
I'm looking for one top plate for rear leafs on a 67-68 4x4 1/2 ton. Longshot but also looking for a decent set of tapered 67-68 rear leaf springs as mine are both cracked. If not I will have to have some made.
01-04-2018, 07:23 PM | #2 |
Re: WTB 67-68 4x4 rear leaf spring plate
I have some plates and springs just not sure what shipping would be!!! oh and the spring length needed? I think mine are 56"
1956 Chevy Bel Air 2 door 1956 Chevy 210 4 Door 1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD 1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E 1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD* GO GO!!! |
01-04-2018, 07:28 PM | #3 |
Junior Member
Shipping might be steep. Could u send me a couple pics? I believe these springs are like 58 inches. They are the tapered 3 inch wide at the ends. 2 leaf
01-04-2018, 08:19 PM | #4 |
You could also convert to a newer spring, but that would require moving mounts.
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
01-05-2018, 01:57 AM | #5 |
Ok so I have the leafs that I added”add a leafs” to because I wanted a little more height. But decided to lift the truck 4” so I removed them. I thought I had the top plates but I can’t find them. So all I have are springs and rear shackles.
If you check out my “Hulk jr build in my signature you will see what I did early on with the leafs. If you want to go with a newer year spring(2-1/2” wide) you will have to change the rear shackles and make spacers for the front of the rear leaf spring mount. Or get extra wide bushings and sleeves which is what I did. I ordered my springs 58”
01-05-2018, 04:30 PM | #6 |
I got a 67 k10 frame going under the knife this week. It has good plates. I will check springs. I know one spring has a cracked eye and I cant remember if its a front or back spring.
