![]() Join Date: Feb 2016
'72 K10 swb cheyenne thoughts
Am considering this truck as a project.
Looks to be an assembled truck, vin indicates it was originally a 6 cylinder, now has an unknown sbc. I know its not a real Cheyenne. Missing SPID. The body has rust issues and some patch panels, very poor bodywork and paint. Frame has rust damage near rear shock mounts, it has not been cut and shortened though. Appears to be the original frame. Don't even know if it runs or drives. The owner is asking $9900. Is it worth that? |
![]() Join Date: May 2003
Re: '72 K10 swb cheyenne thoughts
The pictures make the truck look better than you have described, but they can be deceiving ! Have you seen the truck in person or do you have good pics of the worst areas ? I'd probably pass on it at that price mostly due to the frame damage. Also does the vin tag match the frame numbers. The pass door has been replaced with a 67-71 door or possibly even a cab swap. If you have more pics post them up, it will help members get a better ideal of it's overall condition !
Gary
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 |
I have seen the truck in person.
Unsure about the frame matching the cab, have just assumed the cab is not original to the truck. The pictures do look better than in person. Pic of driver rear frame is the worst spot that I could detect. Some bondo in driver side upper windshield frame too. Front fender mount rust also, not a big deal. The floor has a patch panel on the driver side(no picture). Interior appears to be in good shape, 3 ott, tach in dash, good seat cover. Truck is in storage, no battery to start truck. Has been sitting for several years. |
If you see serious rust issuses in the frame and roof just imagine what the paint & bondo is hiding ! To me it looks and sounds like the truck spent most of its life in the rust belt and it had a cheep patch and paint job. I'd pass on it at that price. If you could get it "MUCH"cheaper and are ready and capable for a major project ??? Maybe ?
More like 6k or 7k
Brian Ritter |
#6 | |
Custom Sport W/T
Location: Tarpon Springs,Fl & Annapolis,Md. ....................Quaint drinking villages with a fishing problem
![]() Join Date: May 2001
I would keep looking for a better truck. that's one looks and sounds like a cobbled up mess.
72 3/4t Custom Deluxe 402/auto 66k Original paint 71 3/4t 4x4 Custom Deluxe 10k original miles Original paint 71 3/4t Cheyenne 402 70k original paint 72 3/4t 4x4 Custom deluxe 72 3/4t 4x4 Custom deluxe 91k original paint 72 Cheyenne/30 Dually 69 Camaro SS396 4-speed 13 GMC 2500HD Duramax I bought new 05 Jeep Wrangler "Willys Edition" 12k miles (I bought new) 85 3/4 ton 4x4 Scottsdale 33k miles original paint 86 1 ton 4x4 SRW Silverado 454 restored 80 1 ton 4x4 SRW Silverado 9,434 original miles!! original paint 95 GMC 1 ton dually 4x4 my dad bought new 95 GMC 3/4 ton 4x4, regular cab 454, 31k original miles 2002 2500HD 4x4 regular cab 6.0L 67k miles 2002 2500HD 4x4 regular cab 8.1L 28k miles 2003 GMC 2500HD 4x4 regular cab Diesel 93k miles 67-72 Parts for sale |
I'm with Custom/10, you don't know what's under the paint. It always gets deeper! I would inspect the the usual - rockers, cab corners, cowl area, cab supports. But, truthfully, unless it went for $2,500 I'd walk. Based on the roof (and assuming it will need rockers & corners) it will be cheaper to replace the cab, you might need a frame or at least section the back 1/2. Then your into a cut down truck. Then there's the drivetrain, no idea of the condition. Also, the passenger door is not a '72 (no screw) so it's possibly a parts/pieces truck?
I would love to have a '72 swb K10, like the color too, but imo, pay more upfront for a cleaner rig - it's cheaper in the long run. |
![]() Join Date: Oct 2009
The single pic of the drip rail/A-pillar is sufficient to run, not walk, away.
Roadtrip!
![]() Join Date: Feb 2003
Too much money for what it is. I would think about 1/2 that if you are just looking for a toy that looks ok.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
I would widen my search. you can have a vehicle shipped from most anywhere in the country for $1000. you would be money ahead in the long run by finding a truck that is not pieced together for less money. there are still lots of them out there.
All about them K’s
![]() Join Date: Jun 2014
Exactly what I was thinking! I’d pay 2500 at very best for it.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 ![]() |
#13 |
![]() Join Date: Jul 2015
I'm going out on a limb here. But it doesn't look that bad. Has the inside been repainted? If not it's very clean original looking. You got to remember these trucks are very old. I gave 2400.00 for a 72 k10 Cheyenne longbed that was a complete basket case. It took 3 trips with a 18ft car trailer to get everything but granted I got a lot of extra parts. All in all the good thing is they make a lot of parts for these truck to fix the bad things. If you want something turn key with no work to be done you might look somewhere else, but your going to need to spend 18000 to 20000.
#14 |
Price is $8400 now, leaning towards buying it. Frame can be rapaired in my opinion. Body work could be interesting. Not an original truck so thinking that it actually frees me up to build what I want. Little on the steep side to start a project with I agree, but seems like it would still be worth 15 to 20 grand even as clone when done. These things are hard to find in my neck of the woods and I have personally seen this one and realise what I might be dealing with before buying. Not buying to flip, but am realistic about having to sell it someday. Appreciate all the feedback and welcome any more that anybody wants to share.
Thanks. |
#15 |
I agree with "Not an original truck so thinking that it actually frees me up to build what I want." My truck is a chopped up parts/pieces truck that will have major parts from at least six different trucks! But, I get to build it my way. If it were an unmolested highly optioned truck I'd have a hard time modding it.
#16 |
Florida Edition
![]() ![]() Join Date: Oct 2010
You can find a MUCH nicer truck for that kind of money. Frame damage, bondo, rusty roof? Don't waste your time.
Trust us, we know.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
#17 |
I will relay a personal anecdote, at risk of being mocked
![]() Once upon a time I bought a very similar truck, in very similar condition, for an almost similar price. I didn't know enough at the time and got suckered by shiny paint in bright colors. And by the fact that it was a '72 SWB K10, one of the desirable and (sort of) rare models. And by the fact that I couldn't find anything else at the time and had been looking for a while. And, finally, by the fact that I thought I had a handle on what fixing the known problems would cost me. Boy, was I wrong. I paid too much for a cobbled truck. My budget for the problems I knew about was wildly off. And my budget for the problems I didn't know about... don't get me started. That truck is long gone, and I learned some invaluable lessons that have made me a much more educated and realistic GM truck buyer/owner/mechanic. But potential lessons aside, I'm going to join the peanut gallery above and say DON'T DO IT! Unless he brings that price down to at least half or less, I'd say keep on lookin'. YMMV... but probably not by much. ![]()
1972 K10 Cheyenne Super | LWB, fleetside | 350/350/205 | KEEPER 1971 K10 Cheyenne | SWB, fleetside | LS Swap 5.3/4L60 | SOLD 1976 Trans Am | 400/4-spd | SOLD 1976 Trans Am | 455/4-spd | TOTALED ![]() |
#18 |
Thanks again everyone, I hear everyone loud and clear. Am a corvette guy and have played this same game with vettes. Still undecided, and have plenty of time to make decision. Appreciate all feedback, good to hear varying opinions.
#19 |
Florida Edition
Come get this one...
https://orlando.craigslist.org/cto/d...443951324.html What I have a such a rare and beautiful truck that are very seldom seen on the road. This all original matching number truck has been in the family for all it's life. My grandfather bought it brand new in 1969 and has kept it garages kept all it's life. This truck has no rust anywhere on the body. Which is real rare since most of these trucks rusted out. The truck has a matching number 350 engine and a 350 4wd transmission. It also come with the wood bed with strips that look brand new from factory. This truck will make it to California and back that's how good this truck has been maintained.
#20 |
Florida Edition
or maybe this one...
https://daytona.craigslist.org/cto/d...398662625.html
#21 | |
Good luck with whatever you decide.
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 |
#22 |
If you have 200+ hrs to spare on bodywork , It looks like mine did , Took 285 hrs .
Stan 67 swb BLU MULE posted via flip-fone |
#23 |
Born Psycho
![]() Join Date: Feb 2001
i agree with Joe. if i were you i would keep looking for something more solid, to me that is a parts truck at best.
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
#24 |
I like it, and 8400 doesn't sound terribly out of bounds. A little rust repair never killed anyone. Fix it as you go. Its a hard to find model and if you want a perfect one, get ready to slap leather. I can buy a lot of patch panels for 5 grand, which is about how much more a perfect one is gonna run. Oh yeah, if you get it, swap the heater hoses, why can't people get that right?
:My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=807535 1972 K10 swb/1968 Camaro 350/4spd 1955 210 2 dr sedan/1998 RCSB Z71 Last edited by tutone; 01-07-2018 at 08:18 AM. Reason: typo |
#25 |
All about them K’s
Rust that high in the roof is more likely to be a cab swap than patch panels...
