Old 01-06-2018, 06:15 PM   #1
Curt - TN
1950 Door Lower Window Track ???
I am trying to put the insides of the doors back together and it appears I am missing parts. It looks like I should have a lower window track that attaches by 4 screws. I think this is the piece the two wheel sections on the window regulator connect to.
I have looked at all of the major catalogs and they do not seem to show one reproduction.
Is there a place to buy these reproduction, I need a drivers and passenger side?
Thanks,
Curt
Brentwood TN
1950 Chevy 5 Window 3100 - Check out my Build Thread: http://67-72chevytrucks.com/vboard/showthread.php?t=724260
1957 GMC 100
Curt - TN is offline   Reply With Quote
Old 01-06-2018, 07:35 PM   #2
crossfire84
crossfire84's Avatar
Re: 1950 Door Lower Window Track ???
I had to get mine off ebay
LIL ERV the 50-3600
396 BBC stroked to 415 cid
Richmond 6spd over drive
C4 rear
Porter built a arms
Never give the Devil a ride,because he'll want to Drive!
crossfire84 is offline   Reply With Quote
Old 01-06-2018, 08:04 PM   #3
flyingdet444
I take it that the window glass was not with the doors? If the glass was in the doors, that piece would be there.
flyingdet444 is offline   Reply With Quote
Old 01-06-2018, 11:23 PM   #4
Curt - TN
I bought the truck as an unfinished project so some parts were missing, this being one.
I think I found two at Chevs of the 40's. They do not have a picture but explain it as this which sounds correct, I just hope they really have two
Door Window Regulator Upper Guide (Cam Track) -Fits All
Item # 4099974 47-50
This is the door window regulator upper guide (cam track) that bolts below the window sash channel.
Curt
Brentwood TN
1957 GMC 100
Old 01-07-2018, 08:14 PM   #5
robertsjm711
robertsjm711's Avatar
If I remember correctly there were two sizes, one early and one later. Not sure when the year break is, maybe when they switched to the wing window (1951?).
Others may have better info, but if you are going to look for used/eBay parts it might be a good question to ask.
And mine do not have holes. I'm not 100% what year my doors are but they have the wing windows.
It was said that if you cut off one hydra head, two more grow back.
-Lernaean Hydra
Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=743246
robertsjm711 is offline   Reply With Quote
Old 01-07-2018, 08:29 PM   #6
Curt - TN
Thanks for the pics. I believe the change to a vent window happened in 1951 and I have a 50 with a single window.
I looked all over ebay for the 47 to 50 which should be longer and have 4 holes and no luck. I am hoping the new ones I found are correct.
Curt
Brentwood TN
1957 GMC 100
