01-06-2018, 11:54 PM | #1 |
under bed floor cross sill supports
I think this piece is also used in trucks so I put this on the truck side. Pic is the floor out of my '77 blazer front edge is up in the photo. Anyone found a close replacement for this piece. (maybe a galvanized sign post? ) I found the smaller one through Auto Metal Direct.
'80 SRW C35 - 355/700R4/4:11/2.5-3/DD '77 Cheyenne K5 - Roller cam 355/NV4500/205/4:88's/35's/DD rust repair on the '77 http://67-72chevytrucks.com/vboard/s...d.php?t=740291 |
01-07-2018, 12:26 AM | #2 |
Re: under bed floor cross sill supports
Can you go down to your local sheet metal place & have them brake you out a couple angles & weld them together & make one?
01-07-2018, 08:49 PM | #3 |
That's a pretty good idea. Sometimes the simple things are a bit elusive.
